At Low idle h22 stalls
Old Nov 18, 2006 | 06:24 AM
wheelmaneg6's Avatar
Default At Low idle h22 stalls
When applying gas the car is fine never cuts off. when I let it sit it idles at around 700 rpm and then the idle drops and it sounds like it starts to missfire and then cuts off. The car sputters when trying to accelerate at low rpm but above 3000 there is no sputter. Any Ideas or help will be appreciated. Thanks
Old Nov 18, 2006 | 06:26 AM
ImPuLsIvE's Avatar
Sounds like you need a tune-up.
Check your spark plugs, wires, dist. cap & rotor.
If that doesn't help, check your fuel filter/pump.
Is your ECU stock, or has it been modified/chipped? That might be the cause of a poor base fuel map.
Old Nov 18, 2006 | 06:56 AM
mgags7's Avatar
clean out your throttle body, IACV, and the fast idle valve
jojogalan
18
Jul 14, 2007 11:51 PM
ge_itr
Sep 17, 2006 08:50 AM
Mik3
Feb 5, 2006 06:55 PM
Vera
Jan 12, 2006 02:41 PM
Kp_VtekNiks
18
Sep 16, 2003 12:10 AM
