how much can a stock ls hold up 2??
Old Nov 18, 2006 | 05:24 AM
crxsteve's Avatar
Default how much can a stock ls hold up 2??
how much boost can a b18a crank and rods hold up 2????
and how are block grauds???
and how do they help out??
Old Nov 18, 2006 | 05:27 AM
civicjdmb16a's Avatar
Default Re: how much can a stock ls hold up 2?? (crxsteve)
Block Guards
Xenocron has a ls that sees 14psi.
Thats alot but i would nt be willing to push it that high unless you have another motor or are willing to rebuild.
If you want to boost over 14.......Sleeve!
Its worth it
Old Nov 18, 2006 | 06:15 AM
Loserkidwac's Avatar
Default Re: how much can a stock ls hold up 2?? (civicjdmb16a)
Make a power goal not a psi goal if you match the right turbo for you goal you waon't have to run crazy high boost to make power...stock LS can make over 300hp and sleezes are good for more than that, I'd be worried about other things failing before i'd sleeve a motor with good tuning you can make good power on an LS I never plan on building a motor since 350whp is more than enough in a light car
Old Nov 18, 2006 | 06:25 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsteve &raquo;</TD></TR><TR><TD CLASS="quote">how much boost can a b18a crank and rods hold up 2????
All of it.
Old Nov 18, 2006 | 06:41 AM
Autoworks's Avatar
https://honda-tech.com/zerothread?id=1323059
read ^
jdmfreshness121890
Dec 13, 2007 02:27 PM
JUANSTURBOTEG
May 18, 2007 06:43 PM
95integraLS003
Sep 13, 2005 05:45 AM
pynikal
Jul 19, 2005 09:58 AM
5gSiB20
11
May 10, 2005 02:15 AM
