What brand of motor oil do you use? What brand of oil filter do you use? Everyone answer!
Old Nov 18, 2006 | 01:45 AM
Kangolbrand's Avatar
Default What brand of motor oil do you use? What brand of oil filter do you use? Everyone answer!
Ok, so its time to change my oil, im woundering what brand of oil do you guys use? Also the brand of oil filter you use?
I've been running Royal Purple but honestly im tired of all the hype and cost.
I want to be different, here everyone is running that royal purple ****.
This may help, I have gsr.
So what oil brand weight do you suggest I run besides Royal Purple... anything better than that or less costly? Thanks
Old Nov 18, 2006 | 04:55 AM
AllMotorDan's Avatar
Honda filter, Penzoil
Old Nov 18, 2006 | 04:57 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (SpoonSirG)
Honda filter, full synthetic 5W30 - either Mobil1 or Pennzoil Platinum, whichever is cheaper. Right now Pennzoil is much cheaper; the oil is $3.97/quart (or $18.97 for a five-quart jug) at Wal-Mart, and through the end of the year, Pennzoil gives you a $15 rebate when you buy six quarts of synthetic.
Modified by nsxtasy at 8:34 AM 11/18/2006
Old Nov 18, 2006 | 05:49 AM
Sam92Teg's Avatar
Default Re: What brand of motor oil do you use? What brand of oil filter do you use? Everyone answer! (Kang
Castrol GTX and Pure One filters, 300,600 miles and counting. Pull my valve cover, and the head looks clean as a whistle.
Old Nov 18, 2006 | 06:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">I want to be different, here everyone is running that royal purple ****.</TD></TR></TABLE>
That sounds like really dumb logic when it comes to what motor oil to use. You should use what works and what you can afford. Just because alot of people use the same motor oil is not reason to use something different. If anything it means you SHOULD use it.
But having said that, I don't know many people here using Royal Purple.
I started using Valvoline MaxLife 5w30 at 118,000 miles, and now at 240,000 miles it still doesn't leak a drop.
Old Nov 18, 2006 | 06:34 AM
vtec2nv's Avatar
anyone here run the s2000 oil filter, instead of the normal honda filter?
Old Nov 18, 2006 | 09:42 AM
soundFX's Avatar
Q advance synthetic is good stuff. smells like sryup
Old Nov 18, 2006 | 09:48 AM
gsrclan's Avatar
Havolin 5W30 dino oil, superTech filter, both from Walmart.
Old Nov 18, 2006 | 10:09 AM
1turbodc2's Avatar
K&N oil filter, royal purple....
Old Nov 18, 2006 | 10:13 AM
silentdeath12886's Avatar
Yea most people dont run purple royal because of the cost. most people ive seen here so far runs mobil 1 full synthetic. tly running mobil1 full syn and mobil1 filter. about to go with honda filter.
Old Nov 18, 2006 | 10:18 AM
RaceMyGhost's Avatar
Default Re: (silentdeath12886)
castrol 20w-50 when its hot
castrol 10w-30 when its not as hot.
puralator oil filter, works great
Old Nov 18, 2006 | 10:23 AM
92DAIntegraXSI's Avatar
OEM honda filter
3. castrol gtx 10w30's and 1. 10w30 gtx high milege
Old Nov 18, 2006 | 10:45 AM
jdm_bones's Avatar
OEM Honda S2K Filter Or Mobile1 Filter with Redline 10w30 for me!
Old Nov 18, 2006 | 10:48 AM
aaronISthrowed's Avatar
I just bought some mobil 1 synthetic about 15 min ago.
Old Nov 18, 2006 | 11:09 AM
1998_4dr_gsr's Avatar
Fram filter with Castrol GTX....been driving honda's for over 10 years and using the same oil change products. No problems
Old Nov 18, 2006 | 11:12 AM
coronadrinker's Avatar
Carstrol GTX 10w 30 and Bosch filter
Old Nov 18, 2006 | 11:25 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (nsxtasy)
The 5W30 viscosity is recommended by Honda as preferred at all temperatures, according to the owner's manual and service manual for the U.S. market. They also say that you can also use 10W30 if it doesn't go below freezing in your area, but that 5W30 is preferred.
Old Nov 18, 2006 | 12:23 PM
Vi3tboy's Avatar
normal valvoline 5w30 with a fram filter or oem filter.
Old Nov 18, 2006 | 12:28 PM
97CGPintegra's Avatar
aren't mobil 1 syn oils made thinner than most oils, which is why people tend to burn/lose oil when switching to mobil 1 5w30?
Old Nov 18, 2006 | 12:55 PM
redGSRguy's Avatar
Default Re: (97CGPintegra)
OEM filter with Mobile 1.
Old Nov 18, 2006 | 02:21 PM
just bought a 5qt of Mobil 1 synthetic... 6.50 a qt. also bought a Mobil 1 oil filter cost 10.99
total about 42.00 dollars for oil change, cost more than royal purple but I though I give it a shot.
Old Nov 18, 2006 | 02:52 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CGPintegra &raquo;</TD></TR><TR><TD CLASS="quote">aren't mobil 1 syn oils made thinner than most oils, which is why people tend to burn/lose oil when switching to mobil 1 5w30? </TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">just bought a 5qt of Mobil 1 synthetic... 6.50 a qt. also bought a Mobil 1 oil filter cost 10.99
total about 42.00 dollars for oil change, cost more than royal purple but I though I give it a shot.</TD></TR></TABLE>
In the U.S, Mobil 1 generally costs $5.47 a quart and $21.97 for a five-quart jug at Wal-Mart, which is less than Sam's Club and Costco, which are $28.99 for a six-quart case. As I previously mentioned, Pennzoil Platinum is much cheaper; the oil is $3.97/quart (or $18.97 for a five-quart jug) at Wal-Mart, and through the end of the year, Pennzoil gives you a $15 rebate when you buy six quarts of synthetic.
Old Nov 18, 2006 | 02:53 PM
Nsane's Avatar
4 quarts of Mobil 1 10w-30 and a hyundai oil fliter (i work at hyundai dealership [all the fliters are the same for em] the threads are the same has b18s so, and they have a valve in them to help oil to get to the cylender head to reduce valve ticking)
Old Nov 18, 2006 | 03:28 PM
95 integra's Avatar
OEM filter, mobil (non syn) 5w-30.
Old Nov 18, 2006 | 04:04 PM
cranny's Avatar
24.224.233.247
i either run Q advanced or castrol syntech , both full synthetic , 5W20. whatever is on sale when i go in , lol.
