Oil Leak on my h22
Old Nov 17, 2006 | 10:45 PM
morales232002's Avatar
Default Oil Leak on my h22
Hi,
Lately I been experiencing oil leaks on my 1993 Honda Prelude Vtech H22 engine every morning under the car. Many times I have to add a quart of oil. Does anyone know what could be the problem and how to fix it?
Thank You
Old Nov 17, 2006 | 11:10 PM
importfanatic17's Avatar
Default Re: Oil Leak on my h22 (morales232002)
Its a swapped engine? I take it that is why you posted here and not in the Prelude forum. Is it a bad oil pan gasket?
Old Nov 18, 2006 | 07:25 AM
Default Re: Oil Leak on my h22 (importfanatic17)
Hi,
I checked my oil pan gasket and it looks good. I decided to take it to a mechanic and he told me it was the seals inside the engine. Could this be the symtoms of oil leaks on my engine aswell. He is charging me $800 to replace seals inside the engine.
Old Nov 18, 2006 | 10:07 AM
hondadude's Avatar
What seals is he replacing exactly?
For that much money I could do a total engine rebuild.
You should find out the exact seals that are leaking and then shop around some.
Old Nov 18, 2006 | 03:31 PM
specbb6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morales232002 &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
I checked my oil pan gasket and it looks good. I decided to take it to a mechanic and he told me it was the seals inside the engine. Could this be the symtoms of oil leaks on my engine aswell. He is charging me $800 to replace seals inside the engine. </TD></TR></TABLE>
you sure the cam seal is not leaking? I replaced that bad boy at 80k miles on my H22.
immalooser
Sep 25, 2009 08:05 AM
Coomer
Jul 14, 2007 04:18 PM
yuen
Nov 12, 2006 06:43 AM
jdmh22luda
Aug 7, 2006 12:48 PM
jdmcivicferio
Jul 10, 2003 07:05 AM
