one more brake question? for a 93 coupe ex w/ rear drums
Old Nov 17, 2006 | 06:26 PM
kit50si's Avatar
Default one more brake question? for a 93 coupe ex w/ rear drums
93 coupe ex my rear drums got stuck my brother had da same problem but we didn't know how to take it out so it got ripped is there anyway I could take w/o ripping it.
Old Nov 17, 2006 | 06:52 PM
JDM KID 510's Avatar
Default Re: one more brake question? for a 93 coupe ex w/ rear drums (kit50si)
What part got ripped?
You can try to let the fluid out of the wheel cylinder, and try to pull it out.
Old Nov 18, 2006 | 06:15 AM
kit50si's Avatar
Default Re: one more brake question? for a 93 coupe ex w/ rear drums (JDM Kid 510)
da brake shoe cuz it embeded it self in da drum so when you try to take it out it would just budge just a little bit. yeah we were at it for about two hours until we decided that f#$% it just rip it boy it didn't look nice we had to replace pins and we didn't know where everything sort of went. you can't just bleed it out it has dat thing dat clicks da one you adjust with a flat screw driver to losen da shoe I was thinking of putting a hole on da drum so I could adjust it but I don't know what bit to use on da drum.
Old Nov 18, 2006 | 11:57 AM
kit50si's Avatar
Old Nov 24, 2006 | 06:26 PM
kit50si's Avatar
Old Nov 24, 2006 | 08:15 PM
Evs-One's Avatar
Solbros Owns Me
learn to speak English and you may get some help
Old Nov 26, 2006 | 05:23 PM
xJDMcoupe's Avatar
Default Re: one more brake question? for a 93 coupe ex w/ rear drums (Evs-One)
Ouch english major well you read the first post. Can you help?
Old Nov 26, 2006 | 05:27 PM
InvaderTrax's Avatar
Use a brake spoon to turn the star wheel to retract the pads
Old Nov 26, 2006 | 05:54 PM
chrisw85's Avatar
The star adjuster is on the bottom of the shoes, the cylinder is up top, if you loosen the bleeder screw to let out fluid and rock the drum back and forth it should push enough fluid out the top wheel cylinder. So now its smaller than the star adjusters width, you'll have more wiggle room to slide it off. Otherwise do what was suggested and take the dust cover acces off for the star adjuster and try and make it smaller; you'll have to lift the metal 'pawl' that lets it only turn one way.
Old Nov 26, 2006 | 07:00 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (chrisw85)
star adjuster is on top, right below the wheel cylinder
Old Nov 26, 2006 | 07:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: one more brake question? for a 93 coupe ex w/ rear drums (xJDMcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xJDMcoupe &raquo;</TD></TR><TR><TD CLASS="quote">Ouch english major well you read the first post. Can you help?</TD></TR></TABLE>
I can't even understand what he says in the first post? Ripped? Are we talking clothes or brakes? We're not speaking ebonix to each other on the corner...the clearer the problem/question, the clearer the answers/help!
Old Nov 26, 2006 | 07:15 PM
chrisw85's Avatar
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">star adjuster is on top, right below the wheel cylinder </TD></TR></TABLE>
oh shoot, i'm used ot working on drums on GM vehicles that use bendix-type drum systems, thats how we got stuff off in class...
Old Nov 27, 2006 | 07:42 AM
kit50si's Avatar
tnx chris get on to dat.
Old Nov 28, 2006 | 12:05 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (kit50si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kit50si &raquo;</TD></TR><TR><TD CLASS="quote">tnx chris get on to dat. </TD></TR></TABLE>
you can't even access the star nut until the drum is off anyway! Not on your Civic that is...
CanyonJunkie
Honda Civic (2006 - 2015)
Jan 30, 2015 04:22 AM
tanjulio
Sep 8, 2012 03:14 PM
lilhatch89
10
Apr 9, 2012 03:02 PM
EJ1chevelle
13
Aug 17, 2007 10:52 PM
B16Civic93
10
Jun 27, 2005 03:32 PM
