ground question for my civic
i have a 1992 hatchback with a mini me swap in it and now after i did the swap it will not turn over. i also took the dash out and painted it black is there some ground on the ignition that would make it not turnover or somethin or is there something under the dash that would make it not turnover.
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
did you check to see if your getting power to the starter?? if your not then try checking the power out of the ign...w/ a meter
what do you mean my starter is gone?
and yes i checked all the connections to the starter i just went and got it tested and it is good postive is hooked up it is grounded to the starter and the little clip on the solenoid is hooked up to the wiring harness thats all right? is there any grounds on the ignition that would make it not turnover??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmyflys »</TD></TR><TR><TD CLASS="quote">yes i checked the starter it has juice where do you check the ignition at</TD></TR></TABLE> ok so if you have power going to the starter why won't it turn over????
it could be many thing's clutch safety switch,the clip for that, the ign...but if you have power going to the starter and it's not turning over then either you motor's locked up or your starters gone....did you try spinning the motor over by hand
yes it turns by hand i had it turned over when i put the trigger switch on one of the distributor wires. it turned over but would keep starting in the on postion. would could be wrong with my ignition.
EGed up from the seat up
May 13, 2010 11:34 PM
