NEED torque specs!!
Old Nov 17, 2006 | 08:17 AM
CiViCgT32's Avatar
Default NEED torque specs!!
i was wondering if anyone could help me out by telling me the torque specs for a b16a head... i gota blown head gasket and need to replace it immediately..
Old Nov 17, 2006 | 10:55 AM
b18bturbo's Avatar
Default Re: NEED torque specs!! (CiViCgT32)
are you using new bolts or are oyu using studs such as arp etc.
Old Nov 17, 2006 | 04:09 PM
Evil_1's Avatar
These are specs from a B16A2 (2000 Si)
Cylinder Head Bolts 61 ft/lb
Camshaft holder plates (8x1.25mm) 20 ft/lb
Camshaft holder (6x1.0mm) 7.2 ft/lb
Camshaft pulley bolts 41 ft/lb
Hope this helps.
Old Nov 17, 2006 | 07:13 PM
DiRty96's Avatar
Default Re: NEED torque specs!! (Evil_1)
head bolts should be a two step sequense... 22 lb ft, and 61 lb ft. and you have a pattern to go by.
9 5 1 3 7
8 4 2 6 10
when you get done go back and torque 1 and 2 again to 61.
Good Luck!!!
in9teg2ra
Apr 23, 2009 06:31 PM
crxkid24
Dec 1, 2006 10:02 AM
Louie_EM1
Mar 24, 2004 09:51 PM
NOOTRON20
Oct 11, 2003 10:18 AM
