93 Civic - Clutch Slave Bleed Screw
Old Nov 16, 2006 | 09:17 PM
93civic2005's Avatar
Default 93 Civic - Clutch Slave Bleed Screw
I have a 93 Civic EX, and the bleed screw on the clutch slave was sheared off. I succeeded in getting that out, but how do I find a new one? I'm not sure what size it is or where to acquire a replacement. Any help on the size? (I'm guessing that I can't just use a brake bleeder screw.) Thanks.
Old Nov 16, 2006 | 09:18 PM
sTEAMD_rICE's Avatar
Default Re: 93 Civic - Clutch Slave Bleed Screw (93civic2005)
honda dealership
Old Nov 16, 2006 | 09:40 PM
umop-apisdn's Avatar
PArt #43352-567-000 to be exact.
Old Nov 18, 2006 | 07:08 AM
Default Re: 93 Civic - Clutch Slave Bleed Screw (umop-apisdn)
Thanks for the help.
Old Nov 18, 2006 | 07:13 AM
93egsir's Avatar
regular parts store would have it too get a speed bleeder while you are at it.
one way valve in the bleeder means no air can get it while bleeding
Old Nov 19, 2006 | 06:45 PM
Default Re: 93 Civic - Clutch Slave Bleed Screw (93egsir)
Yeah, I actually managed to find one that fit at Autozone. Good enough for me!
Old Nov 19, 2006 | 06:56 PM
chrisw85's Avatar
If a bleed screw is about $3 ea and a new slave cylinder is about $15, me personally I'd just get the new slave cylinder; you get a new bleed screw with it plus having the bennifit of a new cylinder.
Old Nov 20, 2006 | 09:23 PM
Default Re: (chrisw85)
A new slave pushes $30 at least, generally.
Old Nov 21, 2006 | 08:39 AM
chrisw85's Avatar
Default Re: (93civic2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civic2005 &raquo;</TD></TR><TR><TD CLASS="quote">A new slave pushes $30 at least, generally. </TD></TR></TABLE>
http://www.stopshopanddrive.co...e.com
$14.54 for a new clutch slave cylinder from sanyco, a leader in OE hydraulic parts for asian car makes. They also make caliper-blanks for Stoptech. So unless you have to have nissin, which is generally the OE maker for Honda, the sanyco will work fine; I have one it works great. Go to kragen and the one from raybestos is $19.99: http://www.partsamerica.com/Pr...60025
Old Nov 21, 2006 | 10:39 AM
Default Re: So unless you have to have nissin, which is generally the OE maker for Honda, the sanyco will w
Ahh, I see what you mean. Noobs like me are wary of generic parts, especially when there's no picture. Thanks for the info though. It's good to know for next time.
Jviper21
Oct 24, 2013 11:17 PM
Mylinh
Sep 25, 2010 04:11 PM
bluenc-87
Apr 30, 2010 08:53 AM
Maple50175
Honda Civic (2001 - 2005)
Nov 2, 2009 12:38 AM
I8Stang
Aug 1, 2004 07:50 PM
