lightened flywheel for my b16?
Old Nov 16, 2006 | 08:27 PM
JDMtype Eg6's Avatar
Default lightened flywheel for my b16?
im puchasing a stage 1 exedy clutch soon and i was wondering what would be the best suitable flywheel for me? i was thinking about getting the 7.5 fidanza flywheel but think it might be to light. my car is for daily driver use and part time drag use. any advice or some experiences with lightened flywheels would be great
Old Nov 17, 2006 | 12:37 AM
Redline130's Avatar
Default Re: lightened flywheel for my b16? (JDMtype Eg6)
For daily driving, I'd stick with a stock one.
Old Nov 17, 2006 | 03:12 AM
graveltravel2's Avatar
or try a 11.5 lb.
stock flywheels generally weigh 17-18 lbs.
well, on a d-series engine that is.
Old Nov 17, 2006 | 04:56 PM
i have a 92 jdm b16 and i (might) buy a jrsc in about 6 months or less, but for now staying na. i was wondering if a lightened flywheel would hurt my performance in the long run. and i hear some bad stories about aluminized flywheels.. also i dont mind getting use to a lightened flywheel for dd, but hope i can get some feedback on experiences with these lightened flywheels.. if possible pls post your flywheels and your opinions on them. thanks
Old Nov 17, 2006 | 10:59 PM
ED9man's Avatar
I have a 9.5 pound Exedy unit on my B16a. There's really no drawbacks whatsoever. I think it makes the car easier to drive as well as more responsive. Makes heel toe easier and it feels like more power gets to the ground. I like the Exedy unit because it is one piece, the gear for the starter is milled on, not pressed.
Old Nov 18, 2006 | 09:53 AM
mmuller's Avatar
Mad Scientist
Default Re: (ED9man)
i have been using act chromoly for a long time now, no problems
Old Nov 18, 2006 | 11:13 AM
blacksi93's Avatar
i have the ACT ULTRA LIGHT, and enjoy the faster throttle responce
Old Nov 18, 2006 | 12:20 PM
clayne's Avatar
Do not listen to anyone who tells you a flywheel can be "too light for the street." Listen to the people who actually have ultra-light flywheels.
http://www.junauto.co.jp/produ...ml?en <- I use the ultra-light 4.2kg in my FD w/ a 6-puck sprung clutch. The clutch itself is more hardcore than the flywheel by far. But other than that, it's not a negative - only positive.
If you drive in stop and go traffic constantly, you might be hating life. But if it's only occasionally, then really it's not a big deal. Hills causing problems is a myth and also a non-issue.
Old Nov 19, 2006 | 12:35 AM
thanks for the replies. im going with the 9.5 exedy flywheel with my stage 1 clutch
Old Nov 19, 2006 | 11:10 AM
clayne's Avatar
Default Re: (JDMtype Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMtype Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies. im going with the 9.5 exedy flywheel with my stage 1 clutch</TD></TR></TABLE>
Sweet, come back and let us know how much you like it too.
Old Nov 20, 2006 | 02:23 AM
b18sihatch's Avatar
get something around 11lbs dont get something stupid light it will be crap for driving daily
b18sihatch's Avatar
assuming your car is a daily driver, lowest i would go would be around 9lbs
Old Nov 20, 2006 | 04:47 AM
clayne's Avatar
Default Re: lightened flywheel for my b16? (b18sihatch)
Yet you haven't - and we have.
Old Nov 20, 2006 | 04:55 AM
Furyof4's Avatar
Default Re: lightened flywheel for my b16? (clayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">get something around 11lbs dont get something stupid light it will be crap for driving daily</TD></TR></TABLE>
Daily drove act prolite 8.8 lbs on a b16 for years, absolutely no problems. It takes a day to get used to...that's it. I'll never go back.
Old Nov 20, 2006 | 05:01 AM
b18sihatch's Avatar
Default Re: lightened flywheel for my b16? (Furyof4)
im also running the prolite, i was running a exedy 9lb clutch, and i didnt have any problems driving on it i actually thought it was pretty easy to drive with it. but my clutch shortly gave out after i got the car so i didnt get to drive on it that long. but its pretty easy to drive with aftermarket flywheels
Old Nov 20, 2006 | 08:37 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">assuming your car is a daily driver, lowest i would go would be around 9lbs</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">im also running the prolite, i was running a exedy 9lb clutch, and i didnt have any problems driving on it i actually thought it was pretty easy to drive with it. but my clutch shortly gave out after i got the car so i didnt get to drive on it that long. but its pretty easy to drive with aftermarket flywheels</TD></TR></TABLE>
You need to make up your mind. You told him not to get a flywheel under 11 lbs, then 9 lbs was ok, and now 8.8 lbs is what used daily and liked it. WTF
Old Nov 20, 2006 | 09:04 AM
b18sihatch's Avatar
some people want best of both worlds, light but not extremely light, so they get somewhere in the middle.
if his car is a daily driver go with 11lb
if its daily/track go with 9
if its solely track go with 7.5
Old Nov 20, 2006 | 01:46 PM
.EnzoSpeed.'s Avatar
if its solely track go with 7.5</TD></TR></TABLE>
So you flip flop a few times, then post this?! That contradicts commonly accepted flywheel theory (heavier for track cars, lighter for street cars).
To the OP - get a ProLite flywheel. Everyone loves them. They drive nice, they don't warp, and they are nice and thick so you can resurface them many times.
Old Nov 20, 2006 | 07:01 PM
clayne's Avatar
Default Re: lightened flywheel for my b16? (.EnzoSpeed.)
Once again, get the lightest normal size flywheel you can find.
About the only exception I would put out here is an ULTRA light 5.5" Tilton race flywheel. This is a straight up race flywheel.
Old Nov 21, 2006 | 06:26 AM
b18sihatch's Avatar
eh i flip flop becuase i dont know the OP intensions with a lighter than stock flywheel, dont know what kinda motor and application he is trying to use, but you are right prolite is the happy medium
Old Nov 21, 2006 | 06:35 PM
Heretic:Si's Avatar
^what? how did you come up with that?
i have an act streetlite, about 12lbs. i wish i would have gone lighter. i can hardly feel any difference between it and stock, driven daily. next time around i'll go lighter.
HitEm'Up
15
Aug 18, 2005 03:27 PM
sleepin'eg
Jun 13, 2005 03:15 PM
civiceg500
Sep 7, 2004 02:57 PM
GSR_Hacker
Dec 4, 2002 01:17 PM
