Valve Seals, Valve lapping Compound?? Help guys
Need some help with Valve Seals. Take a look and see if you could help me out! Thansk guys!
https://honda-tech.com/zerothread?id=1812838
It seems like your question was answered, what don't you understand? BTW, someone said it before but I'll say it again...don NOT use lapping compound at the seal. The compound is to help seat the valves into the valve seats. They come in coarse and fine. Use coarse first, then fine obviously. Take a cordless drill (or corded will work too) and a piece of rubber tubing. One end of the tubing goes into the dril, the other around the valve stem (helps to use zip tie).
Good luck.
Good luck.
SpoolnByYou
Mar 16, 2006 12:49 PM
devand1dawg
Mar 7, 2005 11:53 AM
