Car Wont Start! Broken Crank! =(
Old Nov 16, 2006 | 07:15 PM
vtec420kingH22's Avatar
Default Car Wont Start! Broken Crank! =(
I have a 92 jdm H22a, Pulled my car out of the drive way about 2 days ago went to make a right started to drive a little bit and then my car just died! I was low on gas so I thought it may be gas! Pushed the car home, went to get gas and still the car would not start! Checked battery, still nothing. Checked starter, still nothing.
My mechaninc came over and looked the car over and suggested maybe the msd coil went bad. Went and bought a new one, still nothing! Tried to change out the ignition module in the dizzy and still nothing! Finally after being stuck, and another try to start the car, we noticed that the timing belt was not moving when i tried to start the car.
Maybe broken Crank RIght?
Old Nov 16, 2006 | 07:18 PM
mgags7's Avatar
Your car wont start and you assume the crank is broken??
WTF?
Old Nov 16, 2006 | 07:21 PM
Default Re: (bb4ever)
dont assume read what i wrote..after various tries...the timing belt dont move when i try to crank it! what else could it be
Old Nov 16, 2006 | 07:35 PM
mgags7's Avatar
Have you checked to be sure that the starter is fully engaging and turning the flywheel?
Have you checked that the crank pulley is soundly attached to the crank?
Old Nov 16, 2006 | 08:23 PM
no we have not, and thanks for that advice ill tell my mechanic..anything else?
Old Nov 16, 2006 | 08:32 PM
CGags13's Avatar
Default Re: (vtec420kingH22)
just make sure the engine is turning like bb4ever said...if it is turning and still wont start then...look into electrical (esp grounds coil distributor) then fuel
the crank would not just "break"..you would really have to be beating on it...
i broke a crank in a v8 once..and trust me i knew it was gonna happen..but i kept on driving home b/c i already knew the cheapo reman engine had seriously spun bearings and was shot anyway so i continued...and within 1/2 mile i broke the crank and had to tow it...dammit so close
(i made it 3 miles though in a full-size K-5 blazer)...think about that..thats what it takes to break a crank
Old Nov 16, 2006 | 08:38 PM
Default Re: (CGags13)
yea, i try to learn about my motor but i dont know to much, the motor had just been rebuilt all oem parts and i only have 2000 miles on it. But I know the motor is not moving.
we tried 5 different coils and i bought a brand new internal coil for the stock distributor and it still did not work. We disconnected the msd and tried this!
Old Nov 16, 2006 | 11:09 PM
SPRLude's Avatar
Default Re: Car Wont Start! Broken Crank! =( (vtec420kingH22)
your car wont start if you have a bad crank sensor..
Old Nov 17, 2006 | 06:40 AM
dek1mfk's Avatar
if you just rebuilt your engine, check and see if the crank is on tight like BB4ever said....if youre mechanic was smart, he would have done a couple of hand spins on the crank to see if it would move the timing belt or what not, if it did, then it could just be your crank position sensor...are you throwing any CEL's??
Old Nov 17, 2006 | 11:21 AM
Default Re: Car Wont Start! Broken Crank! =( (dek1mfk)
no, not throwing anything. Not one code.
Old Nov 17, 2006 | 06:22 PM
mgags7's Avatar
did you check to see if the thing is actually spinning or not?
Old Nov 17, 2006 | 06:57 PM
Rosko's Avatar
haha this is just too funny.
does it sound like it normally does when you're turning it over? i don't think you could break the crank and still turn it over without it being obvious that something is completely fubarred.
Old Nov 17, 2006 | 07:30 PM
mgags7's Avatar
lol yea rly....you would think the guy would know that something sounds wrong....
Old Nov 17, 2006 | 07:39 PM
M2B4's Avatar
vtec + h22 + 420 = king of a bad day...
2x0
48
Jun 16, 2018 07:56 AM
mayfly
May 9, 2010 09:39 PM
Chiito4
Jul 30, 2009 08:40 PM
z06eateR
28
Mar 23, 2009 09:38 AM
