Suspension technique Sway bars
Old Nov 16, 2006 | 04:40 PM
Rob.'s Avatar
Default Suspension technique Sway bars
I bought some Suspension Technique Sway bars for my 1990 civic si .
What are the Black brackets for ?
Anything I should know before installing them ?
Old Nov 16, 2006 | 04:42 PM
Tippyman's Avatar
Default Re: Suspension technique Sway bars (Rob.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">I bought some Suspension Technique Sway bars for my 1990 civic si .
What are the Black brackets for ?</TD></TR></TABLE>
I believe they are the mounting points for the rear sway.
Old Nov 16, 2006 | 04:43 PM
mike-y's Avatar
the brackets mount to your factory toe hook locations and serve as the mounting point for the rear swaybar. the 88-91 civic has the swaybar mounted to the underside of the rear chassis, not to the rear subframe like the EG/EK/DC.
Old Nov 16, 2006 | 04:49 PM
Rob.'s Avatar
I found this
https://honda-tech.com/zerothread?id=1656154
Old Nov 16, 2006 | 04:51 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Suspension technique Sway bars (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
I believe they are the mounting points for the rear sway.</TD></TR></TABLE>
Exactly correct. The rear bar is larger and better positioned with the relocation brackets. The rear bar is 3 way adjustable.
I have the kit myself, is awesome!
Here's a couple pics. Until last year, the bars were silver in colour:
Old Nov 16, 2006 | 05:41 PM
Rob.'s Avatar
Default Re: Suspension technique Sway bars (Deetz)
thanks for the pics.
you have any more pics ? or even a writeup ?
Old Nov 17, 2006 | 05:19 AM
JohnnieChimpo's Avatar
The black brackets are for cars that aren't equipped with a rear bar from the factory.
Since you have an Si, you don't need them.
If you'd like to sell the contact me.
Old Nov 17, 2006 | 07:36 AM
Rob.'s Avatar
Default Re: Suspension technique Sway bars (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">The black brackets are for cars that aren't equipped with a rear bar from the factory.
If you'd like to sell the contact me. </TD></TR></TABLE>
ok Im getting them installed today. If they dont use the brackets, they are yours.
thanks
Old Nov 17, 2006 | 07:54 AM
Autoworks's Avatar
thanks</TD></TR></TABLE>
If your talking about the L bracket, then they'll use them.
Old Nov 17, 2006 | 07:55 AM
Rob.'s Avatar
Default Re: Suspension technique Sway bars (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
If your talking about the L bracket, then they'll use them.</TD></TR></TABLE>
no, my car already has them. Si's come with them.
Old Nov 17, 2006 | 07:59 AM
Autoworks's Avatar
no, my car already has them. Si's come with them. </TD></TR></TABLE>
You'll be replacing them witrh the new ones
Old Nov 17, 2006 | 10:22 AM
*Boostwerks*'s Avatar
Those are way more beffy than the stock brackets, so even if you didn't "need" them, I would still use them.
I don't think I would ever bolt on a bigger bar to the completely stock brackets.
Old Nov 17, 2006 | 11:10 AM
Stefndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">no, my car already has them. Si's come with them. </TD></TR></TABLE>
they are different than the stock ones....i did this install on my car pm me if you have any questions
Old Nov 17, 2006 | 11:33 AM
Creator's Avatar
I would like your stock brackets I'm currently using those L brackets on my DX and it only allows for the bolt and not the hook side of the sway bar stabilizer...er whatever u wanna call it
Old Nov 17, 2006 | 12:12 PM
Its me DUB's Avatar
Default Re: Suspension technique Sway bars (Creator)
Keep the stock brackets as well for tow...just incase! The OEM tow brackets will go over those brackets.
Old Nov 17, 2006 | 01:06 PM
Rob.'s Avatar
Default Re: (Boostwerks.com)
well I installed them today. what a huge difference ! everything is so much tighter !
1 lil problem, on the front bushings, the bracket is too small, so its crunching the bushing. The mechanic said the bushing/bracket is too small for the bar.
It fits inside, but its crunching the bushing.
Old Nov 17, 2006 | 06:49 PM
SlobberGoat's Avatar
Default Re: (Rob.)
Whats diameter are the bars?
Old Nov 17, 2006 | 06:53 PM
Rob.'s Avatar
Default Re: (SlobberGoat)
http://www.stracing.com/speedbars.html
22mm front
22mm rear (adjustable)
Old Jan 2, 2007 | 08:37 PM
xyzalvarez's Avatar
Default Re: (Rob.)
*booked!
Old Jan 9, 2007 | 01:27 PM
Skirts's Avatar
Default Re: (xyzalvarez)
So if I dont have the rear brackets what do i do?
Old Jan 9, 2007 | 02:27 PM
xyzalvarez's Avatar
Default Re: (Skirts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skirts &raquo;</TD></TR><TR><TD CLASS="quote">So if I dont have the rear brackets what do i do?</TD></TR></TABLE>
maybe you can fab one, or use the integra braket ....if you have the ST bar, it should come with the braket...if your are using SI or integra sway bars, you can mod the braket,,,,either way you need to unbolt and bolt....GL
Old Jan 9, 2007 | 03:48 PM
Skirts's Avatar
I got the rear sway used and it didnt come with the brackets!
Old Feb 5, 2007 | 09:13 AM
jdm4drSi's Avatar
Banned
That thing has a similar green to the TEIN. Those things would match my TEINS perfectly... humm...
So, how do they perform?
vestalfootball72
Nov 3, 2007 06:17 PM
EFstyle
14
Aug 23, 2007 06:18 PM
Rob.
Suspension & Brakes
20
Nov 27, 2006 09:20 PM
base 5th gen
Suspension & Brakes
Feb 6, 2005 09:03 PM
socalep3
Jan 5, 2004 08:19 PM
