Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Making Friends in rr/ac
Old Nov 16, 2006 | 04:00 PM
AssHippo's Avatar
Default Making Friends in rr/ac
Hi, I'm from Norway. I love Black Metal and racing cars. Just want to say hi and ask you fellows about which brake fluid is good for road race. Ford hi temp fluid boils on me should I use Motul for 15degrees. Thanks. Setup is itr stock brakes ss lines and hawks up front.
Old Nov 17, 2006 | 04:28 AM
granracing's Avatar
I personally like ATE Super Blue.
Old Nov 17, 2006 | 04:38 AM
Zephyr-The Subaru Guy's Avatar
Black metal and racing cars, you're OK in my book.
The ATE Type 200 is good stuff too.
Old Nov 17, 2006 | 05:48 AM
STN_Pat's Avatar
Default Re: (Zephyr-The Subaru Guy)
Was the oil brand new ? I use the prestone/ford oil, too. It does a very good job on the track, but I have to flush the system a few times / summer. the oil absorb humidity quite fast (i guess it would be exactly the same with the motul).
Old Nov 17, 2006 | 05:59 AM
Weston's Avatar
Default Re: (STN_Pat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat &raquo;</TD></TR><TR><TD CLASS="quote">Was the oil brand new ? I use the prestone/ford oil, too. It does a very good job on the track, but I have to flush the system a few times / summer. the oil absorb humidity quite fast (i guess it would be exactly the same with the motul).</TD></TR></TABLE>
You're putting oil in your brake fluid?
Old Nov 17, 2006 | 08:12 AM
AssHippo's Avatar
super blue looks like good stuff, thanks
Old Nov 17, 2006 | 08:25 AM
kaiba's Avatar
Default Re: (AssHippo)
ATE Super Blue
Old Nov 17, 2006 | 10:12 AM
thawley's Avatar
Default Re: (kaiba)
There are several GOOD brake fluids. Read up and see what's available near you.
https://honda-tech.com/zerothread?id=1788969: The ones nearer the bottom of the list are better. Those at the top, worse...
Thawley
Old Nov 17, 2006 | 10:51 AM
granracing's Avatar
The nice thing about using Super Blue is the next time you change the fluid you should use ATE Type 200 (amber color). It makes flushing the system very easy.
Old Nov 17, 2006 | 12:52 PM
polishrifle's Avatar
Default Re: (granracing)
Make sure you do not put DOT 5 fluid in a DOT 3/4 system, otherwise say goodbye to your rubber seals
Old Nov 17, 2006 | 12:58 PM
743power's Avatar
Default Re: (polishrifle)
I &lt;3 Scandinavian metal.
I'll echo the ATE responses.
Old Nov 17, 2006 | 01:11 PM
granracing's Avatar
Regarding the DOT 5 fluid - typically this is made out of a silicone and will not absorb moisture unlike DOT 3 & 4 fluids. What this then causes is the moisture beads to collect in the calipers, can then lead to vapor lock, and result in brake failure. Basically, don't use DOT 5 unless your car specifically calls for it.
Old Nov 17, 2006 | 01:24 PM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">Basically, don't use DOT 5 unless your car specifically calls for it. </TD></TR></TABLE>
I'll add here that the advantages of silicone based DOT-5 fluids are not those that racers care about. DOT-5 does not absorb moisture which makes it great for service interval between flushes, anti-corrosion, military vehicles and collector cars. But its performance at racing temperatures is not as good as what we get with our trusty old DOT-3 and -4 fluids.
BLUE EH3
May 11, 2005 11:12 AM
mnbv
Jul 13, 2004 07:14 PM
importtuner
Feb 22, 2004 06:08 AM
Type-R 940
23
Apr 2, 2002 03:42 PM
