1996 Integra, I can't find the ECU jumper cable to check my CEL code
I have a 1996 integra and I can't seem to find the ECU jumper connector to short to find out why my check engine light went off. I pulled off the kick panel and also unscrewed the glove compartment,
Can somebody post a picture of what the connector looks like?
i have a 2001, so i cant give you a pic but it should be just below the glove box close to the door!!! good luck!
or you can run to your local autozone and have them plug in the OBD2 code reader for FREE...this should be on the passenger side of the console behind the carpeting next to the cupholder area
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">or you can run to your local autozone and have them plug in the OBD2 code reader for FREE...this should be on the passenger side of the console behind the carpeting next to the cupholder area</TD></TR></TABLE>
Autozone FTW!!! Its actually not by the cupholder, but on the very far passenger side of the glovebox on the little 2" strip on the right side of it.....way up under there. Basically bottom of the glove box and to the right about 2"s. If you aren't flipped upside down in the passenger seat, then you aren't gonna find it.
On my girlfriend's homosexual 96 Accord it's behind the ashtray, what the hell was honda thinking?
MonKK
Nov 15, 2008 12:22 PM
Schaz
Nov 5, 2004 11:06 PM
lowboost civ
Mar 31, 2003 08:20 AM
