crackling sound when starting out????
Old Nov 16, 2006 | 11:43 AM
stuie08's Avatar
Default crackling sound when starting out????
alright, i have an 00 civic. And when im starting out at low rpm's in first and second gear there is almost like a crackling sound, not really loud but noticable. any ideas?? also, when car is in nuetral and just reving a tad it sounds like water is flowing somewhere??? anything helps. thanks.
Old Nov 16, 2006 | 11:48 AM
93egsir's Avatar
Default Re: crackling sound when starting out???? (stuie08)
where does the sound come from? Head, block, tranny?
is the noise random or is in related to rpm and constant?
more info please
Old Nov 16, 2006 | 11:49 AM
kevmugen's Avatar
Default Re: crackling sound when starting out???? (93egsir)
bump for more info
Old Nov 16, 2006 | 12:01 PM
stuie08's Avatar
crackling is from around 1-2.5 thousand rpm's and sounds from like almost under my shifter. water sounds like its from behind the head or in the middle of the head and block closer to the steering wheel.
Old Nov 16, 2006 | 12:06 PM
polishrifle's Avatar
Default Re: crackling sound when starting out???? (kevmugen)
my car does this too at WOT under low load, I have no idea what it is or what is causing it, but there is no performance change that I can detect
Old Nov 17, 2006 | 11:55 AM
93egsir's Avatar
when you say crakling? are you talking sparks? metal on metal tinging?
and is there fluid leaking anywhere?
Old Nov 17, 2006 | 12:17 PM
Archidictus's Avatar
Unceasing Measure
Quite possibly spark knock. Take it to someone in your area who can give you a decent diagnosis without charging you an arm and a leg. If you're spark-knocking you need to get it taken care of. If it's something else, another driver or passenger should be able to help identify it.
Old Nov 17, 2006 | 02:05 PM
EJgsr's Avatar
Default Re: crackling sound when starting out???? (Archidictus)
would it be an exaust gasket "flapping" around in 2 bent flanges???
Old Nov 17, 2006 | 09:12 PM
stuie08's Avatar
now do you think a local honda dealer would be able to check it out?
Logan Gallagher
Mar 19, 2019 03:10 PM
bara6075
Oct 6, 2007 02:58 PM
slowassciv33
Sep 12, 2006 12:25 PM
MPALUGHI
Feb 11, 2005 07:14 AM
civicboy95
17
Jan 14, 2004 05:58 PM
