F/S 92 GSR DX INDIANA 30+ PICTURES NO RUST
$7,000 OBO, Clean title, NO rust!! trades = DD + cash
Body ~200km
Custom black
~3-4 dings
hood needs recleared
Engine B18C1 Code ~18km
JDM ITR Bottom End (pistons) w/ balanced GSR crank (lighter) (11.5:1 CR)
GSR Head
USDM 2000 ITR Trans w/ OEM LSD
JUN3 Cams and valve train
AEM 3” Cold Air Intake
Erick’s 70mm Throttle Body
Edelbrock VictorX Intake Manifold
Benen Fuel Rail
RC 310 Injectors
B&M FPR
Fuel Pressure Gauge
Hondata IM Gasket
OEM Head Gasket
JDM ITR distributor
JDM ITR shifter/linkage/bushings
Urethane Motor Mount Inserts
Fluidyne Half Radiator w/ Fan on front
Spec Stage 3 Clutch (6 puck sprung)
Spec 7lb Flywheel
OEM Integra Axles
SMSP Copy Header
Benen Custom Exhaust Piping with resonator with 5zigen tip, no cat.
N1 Crank Pulley (race pulley, alternator only)
Spoon Magnetic Drain Plug
Complete Wire Tuck under hood
No Power Steering
No A/C
Hondata s200 tuned by King Motorsports
P72 ECU
Interior
Skunk2 Shift ****
Integra black seatbelts
No Sound Deadening
Black Rear Panels
Black Rear Seats
Black Carpeted Custom Cover (for rear when not using rear seats)
Optima Red Top Battery in trunk (2ga Wire)
No Roof Liner
JDM ITR Cluster
Autometer A/F gauge
New Black Carpet
Sparco cut off switch
Suspension and Brakes
Tein HA for an ITR
ITR Rear LCA
ITR Rear Sway bar w/ Beaks Mounting Kit
LS Front Sway Bar
Benen front lower bar
Benen Rear Lower Tie Bar
Benen C-Pillar Bar
Integra GSR Front and Rear Brakes
Skunk2 Extended Lug Studs
15/16th Master Cylinder
40/40 Brake Proportioning Valve
Modified by dailydriven at 11:15 AM 12/10/2006
Body ~200km
Custom black
~3-4 dings
GSR Head
Benen Fuel Rail
RC 310 Injectors
B&M FPR
Fuel Pressure Gauge
Hondata IM Gasket
OEM Head Gasket
JDM ITR distributor
Spec 7lb Flywheel
OEM Integra Axles
SMSP Copy Header
No Power Steering
No A/C
P72 ECU
Interior
Skunk2 Shift ****
No Sound Deadening
Black Rear Panels
Black Rear Seats
No Roof Liner
JDM ITR Cluster
Autometer A/F gauge
New Black Carpet
Tein HA for an ITR
ITR Rear LCA
LS Front Sway Bar
Benen C-Pillar Bar
dailydriven
Dec 10, 2006 08:16 AM
dailydriven
Sep 27, 2006 12:08 PM
