stupied question on low beams. they stopped working WTF?
Old Nov 16, 2006 | 10:17 AM
95bkeg's Avatar
Default stupied question on low beams. they stopped working WTF?
I checked the fuses under the sterring colum and they were fine, the high beams work. It was dark out so I could not see a lot under the hood and I am on break between classes but if the bulbs are not burnt out (one was burnt out the other day and I was going to change it but school is busy not both are out) what other fuses or causes could this be (the connectors are good and tight on the headlights)
95 civic ex.
Thanks
Old Nov 16, 2006 | 12:09 PM
jrs2ksi's Avatar
Default Re: stupied question on low beams. they stopped working WTF? (95bkeg)
check the fuses under your hood too. There could be a blown fuse in there from one of your bulbs shorting out. Connection, bulbs, and fuse. Thats the only 3 things u would need to check. good luck
Old Nov 16, 2006 | 01:18 PM
teknoracing's Avatar
Default Re: stupied question on low beams. they stopped working WTF? (jrs2ksi)
Check the under hood fuses. Check the filaments on the bulbs.
ekatz01
Jun 28, 2007 05:48 PM
JDMtype Eg6
Aug 4, 2005 07:36 PM
markyh
Feb 22, 2005 06:25 AM
chochocho
Jan 6, 2005 09:49 AM
egizzle8
13
Sep 21, 2003 05:12 PM
