3" Turbo Exhaust
Old May 8, 2002 | 08:55 AM
PrecisionH23a's Avatar
Default 3" Turbo Exhaust
Yes, i have searched the threads on this and i know that the only company out there that MIGHT do a custom 3" is brullen. Anyways, Im having a hard enough time finding someone that can custom make me a 3" exhaust where the mandrel segments do not crimp on the inside. My question is this, if i use a 2.5"dp and run the 3" exhaust from the end of dp to the very back, how will the 2.5>3" work? I know a full 3" from front to back is the best, but i am just curious how the 2.5>3 will run. Im going to try my damndest to have a custom 3" dp made, but its gonna take a lot of researching. Any info is appreciated, this is for a 94 prelude.
Old May 8, 2002 | 08:59 AM
Smurfylude's Avatar
Default Re: 3" Turbo Exhaust (GudeH23a)
contact Magna flow. I think they will make you one.
Old May 8, 2002 | 11:14 AM
hybrider's Avatar
Why dont u go with that new company 4ricerz and get a 5 inch pipe and u can boost ure way past those SOHC EX civics.........lamerZ!
Old May 8, 2002 | 07:20 PM
Default Re: 3" Turbo Exhaust (hybrider93)
efharisto yia tin kolo exipni apantisi...den mou endiaferi
Old May 8, 2002 | 08:39 PM
LudEcrous's Avatar
silverludesi on this board and on preludeonline has a custom 3inch exhaust w/ a magnaflow muffler and also a 3inch downpipe. you should contact him and see who did his work...they might be able to custom you the same pieces.
Old May 8, 2002 | 08:54 PM
Default Re: 3" Turbo Exhaust (LudEcrous)
you rock, thanks bro!
Old May 9, 2002 | 06:56 AM
dflipmode's Avatar
go to a muffler shop and see what they charge for a 3in from downpipe all the way back....my buddy spent about $500 for them to do it....he even have a 3in cat as well....just buy a turbo muffler and have one of the muffler shops put a custom 3in piping...
dennis
Old May 9, 2002 | 07:19 AM
Default Re: 3" Turbo Exhaust (dflipmode)
none of the local shops can do a mandrel bending that does not crimp the insides of the bends.
Old May 13, 2002 | 11:35 AM
KStuned's Avatar
just buy mandrel bent pieces of piping from http://www.roadraceengineering.com and then have a muffler shop weld it up for you! That is what I am doing. I plan to do it either this weekend or next so I will post pics! just as soon as my turbo shows up! I have everything else!
Let us know what you do, or what you find.
Old May 13, 2002 | 12:29 PM
apexii's Avatar
Don't quit your day job, man.
I know that a 3" DP is not easy, clearing the alternator seems to be the hardest part. I'm having a custom 3" system made, hopefully with a 3" DP, if not it will have a 2.5" flange and a 2.5-3" reducer for that initial clearance. RRE is a good place to get the flanges/pipes, great prices.
http://www.roadraceengineering.com/mandrelbends.htm
kuhwahh
Jan 11, 2011 07:03 PM
Jon5240
Oct 2, 2003 03:01 PM
trustbuddy
Feb 15, 2003 12:09 PM
InfamousRS
Jan 22, 2002 10:07 AM
