help with skunk2 intake manifold? vacum lines
im actually taking off my skunk2 IM and re-installing my OEM GSR IM probably this Friday. ill look at the hoses, and write up a how to, since i had no luck finding a how-to for my ODB2 setup.
i got the bottom bolts off with a low-profile ratchet wrench
it is just a regular ratchet wrench that you can stick a low profile socket into
and skinny hands always helps
it was easy to get on i just don't have the directions and don't know where all the vac lines go, so please take as many detailed pics as you can and i would be forever gratefull
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robstunner4 »</TD></TR><TR><TD CLASS="quote">im actually taking off my skunk2 IM and re-installing my OEM GSR IM probably this Friday. ill look at the hoses, and write up a how to, since i had no luck finding a how-to for my ODB2 setup.</TD></TR></TABLE>
dont like the manifold anymore?
well i talked to skunk2
and they said
all you need is the vac for the FPR it goes to the closest small one
then the brake booster to the big barb on top
and the other big barb goes to the pcv valve
the other small one gets capped
vboy714
Jan 18, 2005 01:45 AM
