RSX-s, what makes it stronger then the base?
Old Nov 16, 2006 | 09:41 AM
PhilTran.o7's Avatar
New User
Default RSX-s, what makes it stronger then the base?
What makes the RSX-s Stronger then the Base model? they both have the same engines right?
so what parts make the type-s stronger?
Old Nov 16, 2006 | 09:52 AM
savinGAShaulinAss's Avatar
Default Re: RSX-s, what makes it stronger then the base? (PhilTran.o7)
im not exactly sure but i do know that the type-s motor has the i-vtec that switches to a big lobe at a certian rpm(like regular vtec)the base model rsx has the same motor as the civic si(ep3)the i-vtec in that motor is similar to the vtec-e d-series in that at low rpms only 3valves open and close causing a swirl in the cumbustion chamber giving better economy then at a certian rpm(vtec crossover)the motor uses all 4 valves getting better performance.thats all i know
pias
19
Apr 10, 2009 09:34 PM
wutami7
Nov 17, 2005 01:44 AM
IGGY
Feb 1, 2005 06:00 PM
mini-cRx
Mar 20, 2004 09:01 PM
RR98ITR
28
Sep 13, 2003 02:40 PM
