Muffler comming off mounts?
Old May 8, 2002 | 08:43 AM
onyx00's Avatar
Default Muffler comming off mounts?
My muffler keeps comming off it's mounts; those two rubber ones in the rear. Muffler is stock, as well as b-pipe. Never touched the muffler for anything.
anyone got any ideas why this is happening? It worries me because obviously it is not good for the muffler to just hang there. Any suggestions on what to do to stop this?
I was thinkng of taking some silicon and putting it in the holes of the rubber mounts where the muffler hooks in. Good idea?
Old May 8, 2002 | 09:01 AM
GRM Scott's Avatar
25 Year Member
Default Re: Muffler comming off mounts? (onyx00)
Sounds like something upset the fit...is your carsound cat too short?
Old May 8, 2002 | 09:05 AM
Money Hou$e's Avatar
That's what you get for living in AZ, must be the heat or something.
Old May 8, 2002 | 09:12 AM
BudMan's Avatar
Default Re: Muffler comming off mounts? (mltdown)
take it to any local muffler shop & have them spot weld a washer on the end of each prong. You will still be able to pull them off w/pliers if you needed them off, but that'll keep the muffler on.
Question = How many miles do you have on the car? Your stock motor mounts are probably just worn out & that's letting the motor shift front-back more than originally intended. Get the ES mount set & install all 3 - problem solved
Old May 8, 2002 | 09:25 AM
py1188's Avatar
Default Re: Muffler comming off mounts? (BudMan)
Sounds like they could just be worn out.
Best way is to get under there and check things out for yourself
Old May 8, 2002 | 12:34 PM
onyx00's Avatar
Default Re: Muffler comming off mounts? (py1188)
Will do, thanks guys.
Old May 8, 2002 | 01:54 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
budman's suggestion is the best.. and he has a lot of eperience with his exhaust falling apart!
-Dave,
Old May 8, 2002 | 02:35 PM
Nate's Avatar
funny dave
olddohc
Jan 13, 2012 01:28 PM
choji
Sep 6, 2008 09:06 AM
tpot90
Jan 3, 2008 04:06 PM
Jvs10
Jun 27, 2006 08:26 PM
lowRIDAH
Oct 2, 2005 01:25 PM
