Engine pics, work still in progress.
Old Nov 16, 2006 | 03:22 AM
vtechatch's Avatar
Default Engine pics, work still in progress.
I have been working on this car, a 98 Civic. I ordered all new bolts from bellhonda and have yet to recieve them. Here is from beginning to current.
Current:
Full Exhaust:
Modified by vtechatch at 8:17 PM 11/16/2006
Old Nov 16, 2006 | 05:32 AM
hondaman86's Avatar
Default Re: Engine pics, work still in progress. (vtechatch)
it cleaned up nicely
Old Nov 16, 2006 | 05:49 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Where's the catalytic convertor?
Old Nov 16, 2006 | 06:28 AM
fdjizm's Avatar
its right after the header even though its not a catalytic converter, but it keeps the code away, its more like straight pipe.
Old Nov 16, 2006 | 06:36 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (fdjizm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdjizm &raquo;</TD></TR><TR><TD CLASS="quote">its right after the header even though its not a catalytic converter, but it keeps the code away, its more like straight pipe. </TD></TR></TABLE>
Get a high flow cat, or any cat.
Old Nov 16, 2006 | 06:40 AM
vtechatch's Avatar
That's actually a resonator. I took the cat off it was attached to the stock Exhaust manifold. Next I'm thinking of removing the power steering just because I don't like how it looks. None of my several Civics had power steering.
Also I am changing all the bolts in the engine bay with OEM ones. They are only like .40 each. I'm also going to polish the Valve cover more until it is a mirror like sheen.
I ordered a D16Y8 Manifold with throttle body and all sensors. I'll buy an aftermarket throttle body if I find I need it.
Dan
Old Nov 16, 2006 | 09:46 AM
dohcVTECeg2's Avatar
Default Re: (vtechatch)
OH snap!! blue wires and hoses!! **** Is clean s0n!!!!
Old Nov 16, 2006 | 09:58 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">OH snap!! blue wires and hoses!! **** Is clean s0n!!!!</TD></TR></TABLE>
Here in the States we call those hoses purple
Also, why spend so much money on OEM Honda bolts when you can probably order a fist-full of ARPs from Summit for much less money?
I suggest you scuff-sand the aluminum of your distributor and paint it black
Old Nov 16, 2006 | 10:01 AM
HondaJack's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
I suggest you scuff-sand the aluminum of your distributor and paint it black </TD></TR></TABLE>
I was thinking the same thing but you beat me to it
Old Nov 16, 2006 | 11:10 AM
EG_GSR's Avatar
Default Re: (HondaJack)
a little wire tuck, no power steering and a aluminum radiator will clean it up really nice to. mayeb put a y8 head on later.
Old Nov 16, 2006 | 11:25 AM
vtechatch's Avatar
I came out to about 30 something bux, that's including new brackets for coolant resevoir etc.
I'm gonna clean up the dizzy and the block...I'm probably gonna wire brush it and use some mothers aluminum polish.
I wanna stay NON-Vtec. I'm gonna get another Y7 head for cheap on ebay and bring it to my boys at the machine shop I used to work at and I'm going to Cam it. . .Delta 282 as of now or maybe exospeed.
If I can get the wheel Horsepower of a stock B16 I'll be happy, actually that's my goal.
Dan
Old Nov 16, 2006 | 11:53 AM
kevmugen's Avatar
why the purple (not blue) hoses?
Old Nov 16, 2006 | 12:05 PM
93egsir's Avatar
Just keep in mind that if you remove the power steering system and leave the p.s. rack in it may be harder to turn than a vehicle that doesnt have power steering.
also if the rack has no fluid in it they tend to wear out faster so I hear
Old Nov 16, 2006 | 12:16 PM
POE's Avatar
POE
Default Re: Engine pics, work still in progress. (93egsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsir &raquo;</TD></TR><TR><TD CLASS="quote">Just keep in mind that if you remove the power steering system and leave the p.s. rack in it may be harder to turn than a vehicle that doesnt have power steering.
also if the rack has no fluid in it they tend to wear out faster so I hear</TD></TR></TABLE>
i can vouch for that!
Old Nov 16, 2006 | 01:18 PM
dangthemang's Avatar
curious.. what kinda intake is that?
Old Nov 16, 2006 | 03:48 PM
petty$rep's Avatar
Default Re: (dangthemang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Get a high flow cat, or any cat.</TD></TR></TABLE>
also i think that once you get a new head for the motor and have the machine shop take car of that you will have a pretty good set up IMO.
Old Nov 16, 2006 | 03:55 PM
EX-T's Avatar
Default Re: (petty$rep)
looking better!
Old Nov 16, 2006 | 03:57 PM
vtechatch's Avatar
Default Re: (EX-T)
It's a $6 dollar CAI from Ebay. I only used half cause this is my daily driver and it rains alot here.
Here's some of the parts I just got today. I already put some on.
Old Nov 16, 2006 | 04:24 PM
HiProfile's Avatar
I'd guess that filter came with the cai too. If so - $6 is getting you a pink paper filter - less power than stock.
As for the cam - it very well could make it more like a stock b16. No low end, everything up top. The only problem is the y7 heads flow so much less, that I doubt it will work that way. You'd be MUCH better off buying a y8 intake manifold, esp since you'll be trying for upper-rpm power.
Good luck, just don't get too caught up in OEM parts. A few bucks here and there can add up to that of a y8 mani eventually.
Old Nov 16, 2006 | 05:04 PM
vtechatch's Avatar
Default Re: (HiProfile)
The Filter is a K&N. The one that came with it fell apart and I trashed it.
I already got the Y8 manifold and when I get my head ported it will flow way better than a stock SI head.
I'm working the head. Valves, Springs, Etc
Modified by vtechatch at 12:18 AM 11/18/2006
Old Nov 17, 2006 | 04:42 PM
POE's Avatar
POE
how much did u pay for all those new parts.. the honda ones..
and zex 59300 cam and valve springs are a good mod.. and love boost
Old Nov 17, 2006 | 04:49 PM
Eran's Avatar
HT White Ops
Looking great, but lose the blue, IMO.
Old Nov 17, 2006 | 05:41 PM
JeffBro's Avatar
Dude that exhaust is gonna be really loud with no cat on there. Just to let you kno
Old Nov 17, 2006 | 05:45 PM
deadline's Avatar
Default Re: (ek forever guy)
keep the air clean man !!
Old Nov 18, 2006 | 02:25 AM
vtechatch's Avatar
Default Re: (deadline)
There are about $25 worth of parts in the pics. All the Honda parts from bellhonda came out to 66$. Keep in mind that in that pic is only about a 1/3 of the parts.
The car is extremely loud without the silencer.
With the silencer it is very very mellow....almost stock.
I was thinking of losing the blue intake hoses. I wanna keep the radiator hoses and plug wires.
Any other ideas are apreciated.
Dan
