D16z6 in 91 STD, reviewed
Old Nov 16, 2006 | 03:19 AM
GarageAlchemist
Guest
Posts: n/a
Default D16z6 in 91 STD, reviewed
so i blew my d15b2 on my daily, and i have an extra d16z6 laying around. Gonna keep the d15b 4 speed tranny, drop in new mounts, the d16z6,
all i ned to do is get a
d16z6 ecu(p28, or p06/converted)
d16z6 wire harness ?
run lines for the vtec sol
anything else i'm missing ?
Old Nov 16, 2006 | 05:04 AM
redzcstandardhatch's Avatar
something different
its not easy to use the z6 harness on an ef . you will need parts off that harness, but the accepted method of converting from dpfi-mpfi obd1 is to convert the stock harness to mpfi, and then buy an obd0-obd1 harness.
Old Nov 16, 2006 | 01:51 PM
blackeg's Avatar
Default Re: (redzcstandardhatch)
dpfi-mpfi swap and an obd0-obd1 conversion harness, its not too bad.
trust me, you want to get the 5 spd tranny, it makes life a whole lot nicer. this is coming from a guy who had a z6 4spd 91 hatch for like 25k miles, and now has the same motor in a 90 hatch with a 5 spd for 8k miles
Old Nov 16, 2006 | 04:03 PM
ED6JDM's Avatar
Default Re: (blackeg)
WOW! I never thought someone would be doing the same thing I just did. I have a ED6(STD) with a JDM(z6). What you really need to make this complete is
1. http://rywire.com/store/8891-c...d5abd
2. a 89-91 Si tranny(cable) well that's what I did, no need to convert to hydralic
3. p28
4. shift linkage won't matter if you use a cable Si tranny
5. all of the stock motor mounts from your d15b2 especially your driver side mount (make sure you take off the complete driver side mount)
6. And pray theres no rust!
Old Nov 16, 2006 | 06:25 PM
dr_latino999's Avatar
Default Re: (ED6JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED6JDM &raquo;</TD></TR><TR><TD CLASS="quote">(make sure you take off the complete driver side mount)
</TD></TR></TABLE> Clarification for the slow ones like me --&gt; Take off the engine mount and the bracket that mounts the actual block to the mount. Yes, the thing under the timing cover.
Old Nov 17, 2006 | 02:03 AM
blackeg's Avatar
Default Re: (dr_latino999)
^^^ yep. my timing belt cover had to be trimmed up a tiny tiny bit too, no big deal
Old Nov 17, 2006 | 04:27 PM
ED6JDM's Avatar
Yes, you have to do this if your expecting to put a z6 engine into the ed chasis. The complete bracket next to the waterpump and tension must be removed from the stock engine and put on the z6 block. That's the only way.
Old Nov 19, 2006 | 08:28 AM
GarageAlchemist
Guest
Posts: n/a
what if i just reuse my 4spd tranny ?, and why in gods name does a wire harness cost 300$ from rywire.. lol
seriously.. thats nuts.
Old Nov 19, 2006 | 12:53 PM
ED6JDM's Avatar
Default Re: (GarageAlchemist)
I don't think you can use the 4sp tranny! The z6 is 5 speed! Well with the rywire price that's their price but if you want to spend time adding alot of sensors to your stock STD engine harness go right ahead .
Old Nov 19, 2006 | 01:00 PM
AJxr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED6JDM &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you can use the 4sp tranny! The z6 is 5 speed! Well with the rywire price that's their price but if you want to spend time adding alot of sensors to your stock STD engine harness go right ahead . </TD></TR></TABLE>
what?
engines themselves dont have speeds. you can use the 4 spd tranny, but as other people said i say get at least a 5spd tranny. you dont have to add any sensors, just the stuff for mpfi and buy yourself a vtec subharness. then do like they already said with the obd0-1 conversion and your pretty much set.
Old Nov 20, 2006 | 03:37 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (AJxr)
any of you guys know where i can get the obd0-obd1 conversion faq, i already know the mpfi swap part, thanks
Old Nov 21, 2006 | 10:50 AM
GarageAlchemist
Guest
Posts: n/a
bump
Old Nov 21, 2006 | 11:07 AM
EJ1 wilcox's Avatar
I have an STD with a d16z6 in it.
I did the DPFI to MPFI conversion, and then bought an OBD0 to OBD1 conversion harness of eBay for like $40.
Worked perfectly, cranked right up w/ no CELs. Everything works great
Since I used an OBD0 to OBD1 harness, I didn't have to mess with anything other than running a few wires and plugging in my p28.
I've always wondered what it would feel like with the 4-speed. I have one in my garage that I've never used before. I'm running an Si tranny.
Anyways, the swap is pretty simple and has been done a million times before, so there are plenty of people who can help you.
Good luck
Old Nov 21, 2006 | 11:21 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (EJ1 wilcox)
http://www.angelfire.com/d20/h....html
there are a few how to's online if you feel like doing it yourself
Old Nov 21, 2006 | 11:22 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (HondaPartsHero)
awesome, wilecox did you reuse the 4 speed tranny ?
Old Nov 21, 2006 | 11:34 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">awesome, wilecox did you reuse the 4 speed tranny ?</TD></TR></TABLE>
Nope, I have it sitting in my garage still. I might keep it around as a spare in case I mess up my Si tranny.
Old Nov 21, 2006 | 12:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">any of you guys know where i can get the obd0-obd1 conversion faq, i already know the mpfi swap part, thanks</TD></TR></TABLE>https://honda-tech.com/zerothread?id=1319235 Running my car CEL free for 6 months now
Old Nov 21, 2006 | 12:18 PM
GarageAlchemist
Guest
Posts: n/a
interesting, if i swap to the 5speed tranny thow don't i have to change the axles ?
Old Nov 21, 2006 | 12:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">interesting, if i swap to the 5speed tranny thow don't i have to change the axles ?</TD></TR></TABLE> Not unless you change your hubs.
Old Nov 21, 2006 | 12:33 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1319235 Running my car CEL free for 6 months now </TD></TR></TABLE>
2 months and no CELs. I have everything wired up including the Honda scan tool connector
Note: Cheap harnesses will be a headache, it is a hit or miss with them.
Old Nov 21, 2006 | 12:59 PM
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">I have everything wired up including the Honda scan tool connector </TD></TR></TABLE> Showoff
Old Nov 21, 2006 | 01:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Showoff </TD></TR></TABLE>
What?
*pulls out Honda scan tool*
Old Nov 23, 2006 | 10:58 PM
EDSEF's Avatar
Im actually looking into doing this swap. My engine is slowly dying and i found a D16Z6 with low miles for cheap. Everythings included, harness and ECU too. So can u use the tranny thats on the D16 or no??? If not, i know the si trannys better, but could i use my DX 5spd tranny thahts in my 91 sedan right now? Just looking for a cheap as posible fix, and a little more powers always nice haha.
CRXosaurus
Apr 1, 2013 04:36 AM
bluelsvtecda9
Jan 27, 2007 03:17 PM
rsdracing
Jul 19, 2006 01:32 PM
memorybox
Jul 4, 2006 10:06 AM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
