92 civic dx wont start
Old Nov 15, 2006 | 10:48 PM
Panoply's Avatar
Default 92 civic dx wont start
hey guys, im having problems with my car not starting. its a 92 civic dx, completely stock commuter car. about 6 or so months ago i had to re solder the main relay cause the fuel pump wasn't turning on now im running into a problem of no spark.
i bought a new cap and rotor and its still not sparking, as well i replaced the coil and ignitor from another distributor (im not sure that it was good either, but just to try) to no avail it still will not start for me. upon further inspection of removing the distributor it looks as if the plugs were jammed together like someone had no clue how to plug a distributor up. this caused some of the pieces of the 2 plugs to break off. however, it still seems as if everything is making a good, tight connection.
if my plug wires, cap, rotor, coil and ignitor were good what else could it be? im going to try to replace the entire distributor with a known working one hopefully tomorrow, but if anyone has any idea of what i could try otherwise that would be great. thanks in advance.
Old Nov 16, 2006 | 05:31 AM
wzachmorris69's Avatar
Default Re: 92 civic dx wont start (Panoply)
i have a 95 dx and it just stopped starting and i took it to a shop and they charged me 800$ for a fuse. Check your fuses. The one i had a problem with was the fuse box under the dash .
Old Nov 16, 2006 | 05:38 AM
Turbogixxer's Avatar
Do not ASSume it is making a good connection. Check it with a mutli-meter. You getting power to the coil?
Do you have red dust in the distributor? You have any codes?
Old Nov 16, 2006 | 11:37 AM
Panoply's Avatar
Default Re: 92 civic dx wont start (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wzachmorris69 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 dx and it just stopped starting and i took it to a shop and they charged me 800$ for a fuse. Check your fuses. The one i had a problem with was the fuse box under the dash .</TD></TR></TABLE>
ok, ill check under the dash as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Do not ASSume it is making a good connection. Check it with a mutli-meter. You getting power to the coil?
Do you have red dust in the distributor? You have any codes?</TD></TR></TABLE>
i was planning on trying to check it with the multimeter tonight. when taking the distributor apart i did not notice any red dust, what would this be from? and no cel.
Old Nov 21, 2006 | 10:15 AM
Panoply's Avatar
well i got the car running again awhile ago, and it ended up having a bad coil/ignitor (got spark after we replaced it with a good one), one bad spark plug, and had jumped a tooth on the timing belt. crazy how all that happened at once.
mastapw7
Jan 21, 2012 11:31 AM
eskimo10
Aug 23, 2007 01:25 PM
rhiannonsboo
Dec 31, 2006 01:01 PM
gottats25
Jun 29, 2005 05:07 PM
sniperslayer
Sep 20, 2004 05:59 PM
