wanna know some good times for a ls v-tec??
Old May 8, 2002 | 08:15 AM
eddiecut's Avatar
Default wanna know some good times for a ls v-tec??
just wanted to know what you guys are running for ls v-tec and what some of the set ups and times are?
Old May 8, 2002 | 08:33 AM
WAFFLES's Avatar
Default Re: wanna know some good times for a ls v-tec?? (eddiecut)
My friend has one w/ itr pistons all new bearings and seals, vtec pumps b16 head with CTR intake cam and intake mani. header and exhaust in a EF hatch. Best time was 13.5 with a CM stage 3
Old May 8, 2002 | 08:34 AM
ExospeedAMcrx's Avatar
many diff factors you know. what car its in, diff. setups on the motor. etc.
Our LS/V in a CRX with CTR pistons did a 12.9 @106mph.
Wil
Old May 8, 2002 | 09:04 AM
eddiecut's Avatar
Default Re: wanna know some good times for a ls v-tec?? (exospeedAMcrx)
mine is in a 92 si but i wasjust wondering what some other people were running on theres
Old May 8, 2002 | 10:12 PM
eddiecut's Avatar
Default Re: wanna know some good times for a ls v-tec?? (C5_ALLMOTOR)
with ful interior and street tires? i would like to get my car in the low 13 maybe just maybe the 12 with full interior and street tires but with ls-vtec that may be hard i was thinking of doing cr vtec instead now
Old May 9, 2002 | 06:17 AM
MyWhiteCivic's Avatar
Default Re: wanna know some good times for a ls v-tec?? (WAFFLES)
If you do the V-TEC conversion on the LS motor, can you still run boost on it because I have heard that it can make the engine very touchy when it comes to boosting it. Oh and on another sidenote... can you swap in any Honda DOHC head to a LS motor to make the conversion? Sorry, I'm a newbie so I ask stupid things.
Old May 9, 2002 | 06:37 AM
4g4me's Avatar
Default Re: wanna know some good times for a ls v-tec?? (MyWhiteCivic)
All I know is that you have 4 choices for the head.
1. b16b (ctr)
2. b16a (sir)
3. b18c1 (gsr)
4. b18c5 (itr)
You can use any of these heads. Of corse the ITR and the CTR heads will be expensive and hard to find, but they are an option. As far as boost, I don't knowmuch about the hybris b series, but I know that all the vtec heads are tuned for high revving power, and all the non-vtec blocks are tuned for low end torque, and have a lower rev limit. This already means that you will be stressing your lower end. Boosting on a ls/vtec with a stock lower end is a nono, even though i think that you will have low compression. But like I said, I don't know much about the hybrid b-series motors.
Old May 9, 2002 | 06:41 AM
Default Re: wanna know some good times for a ls v-tec?? (4g4me)
So it might actually be better to go with a B16A engine as apposed to the Teg LS because of the way it's built and the stock rev limit? Makes sense... thanks.
Old May 9, 2002 | 07:19 AM
eddiecut's Avatar
but tunning the vtec and the turbo is pretty hard and if you go with just an ls block it can handle a load of boost with just a stock bottom end
ls with turbo is a good combo and it is way cheaper
Old May 9, 2002 | 08:46 AM
Yeah but an LS engine has a lower redline so wouldn't it make more sense to buy an engine with a higher one... like a B16A?
Old May 9, 2002 | 08:57 AM
xJ.SLOTHx's Avatar
ive had the luck of driving a fully built LSVTEC turbo hatch (EK) and all i have to say is BOOST OWNZ JOO~ especially after driving that car, the acceleration factor is like none other. I've been in fast N/A cars but it just doesnt compare.
Boost
Old May 9, 2002 | 09:44 AM
slammed_93_hatch's Avatar
mywhitecivic- the only thing the redline is there for is so you don't hurt the motor and there is not sense in reving that high when you don't make power up there. rev limiter is were it makes no sense to rev higher B16b revs higher then a H22 type s but the H22 type s makes way more power SHOC vtec's rev just alil bit high then an LS motor but the ls motor makes way more power
Old May 9, 2002 | 10:09 AM
Default Re: wanna know some good times for a ls v-tec?? (slammed_93_hatch)
But turbos for a B16 or B18 series engine like the T3/T4 take a while to spool up so when you hit full boost at 4k you only have till mid 6k to boost. I can't see that being very helpful??? Help!!!
Old May 14, 2002 | 09:58 PM
infamousALLMTR's Avatar
OH MY GOD!!! why didnt you let us help you build it it would of been faster...
you have been slapped in the face by SPEEDYNAMIC
Old May 14, 2002 | 10:45 PM
l's Avatar
l
the Lsvtec EG in my sig made more power up higher than a 200whp GSR
build it right and it will rev like no tomorrow
Old May 15, 2002 | 12:10 AM
xJ.SLOTHx's Avatar
dont forget about the gearing on a LS...and a b16 can rev easily to about 8200 rpm
drunknbass
Apr 20, 2003 12:17 PM
eddiecut
Nov 3, 2002 12:23 PM
vpforeva
Sep 28, 2001 12:59 PM
Integra187
Jul 16, 2001 10:55 PM
