fuel or timing?
Old Nov 15, 2006 | 10:29 PM
GsrTurboCRX88's Avatar
Default fuel or timing?
I am working on a 90 civic dx that is having a wierd problem. when it first starts up it runs great but after a couple minutes of driving,after I stop then step on the gas i get very little response, i can hold the pedal to the floor and be barley moving, then once i get higher in rpms it runs fine. WTF? I just did a tune up and it didnt help much.
Also i have noticed that it gets worse when i am lower in gas. It has broke down on me twice and code 16 pops up which is fuel injector
Default Re: fuel or timing? (GsrTurboCRX88)
i have tested the injectors and they tested good but i havent had my DVOM with me when it has broke down
Old Nov 16, 2006 | 09:04 AM
up
Old Nov 16, 2006 | 09:22 AM
slywfbpsi's Avatar
fuel pump
Old Nov 16, 2006 | 09:24 AM
Default Re: fuel or timing? (slywfbpsi)
if it was the fuel pump wouldnt it not start?
Old Nov 16, 2006 | 09:30 AM
wiZCo's Avatar
Stouts 'n' Scotch
It's worth checking out. Probably wouldn't hurt to change your fuel filter and run some seafoam through the system, it may just be a dirty or clogged injector.
Old Nov 16, 2006 | 09:43 AM
Default Re: fuel or timing? (wiZCo)
ok, i will do some testing but would that cause a fuel injector code?
Old Nov 16, 2006 | 09:45 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">ok, i will do some testing but would that cause a fuel injector code?</TD></TR></TABLE>
Yes, if you have crap in your fuel system it can clog the injectors, leading to the injector code. I suggest doing those two things before you try ripping out the fuel pump (it's a PITA), they can be done very quickly and easily.
Old Nov 16, 2006 | 10:47 AM
v8Buster's Avatar
i had a fuel pump go out on me, but could be the FUEL SCRAPER, it would start but would bog and not go anywhere.
tightDA8
Jul 3, 2019 08:16 PM
civicef990
10
Nov 10, 2010 11:04 PM
thatnikkashoD
Feb 23, 2008 08:54 PM
Dan-Dillinger
Apr 21, 2006 11:26 AM
Backk InTheDA
Feb 24, 2005 03:52 PM
