redline? tach......... mileage....
Old Nov 15, 2006 | 10:14 PM
IP RACING's Avatar
Default redline? tach......... mileage....
ever since I got my car my car has not been able to redline.. Ive pushed it and it just cant redline.. it makes kinda like a popping noise when I hit 5600... all power is still there just seems restricted... and my speedometer doesnt work along with my mielage.. does anybody know if its a related problem.. anything serious.... easy fix?
Old Nov 16, 2006 | 09:11 AM
ckyguy's Avatar
auto or manual? and your speedometer/odometer don't work at all or don't work right?
Old Nov 17, 2006 | 12:12 AM
IP RACING's Avatar
Default Re: (ckyguy)
5 speed and they do not work at all.. my speedo is down at past 0.. and my mileage has been on 153.316.4 since I got the car
Old Nov 17, 2006 | 01:41 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (IP RACING)
If you have a bad VSS (Vehicle Speed Sensor) your car will run in limp mode... hence why you can't reach redline.
Old Nov 17, 2006 | 10:00 AM
IP RACING's Avatar
Default Re: (JDM_Ej)
is this most likely the problem...
Old Nov 17, 2006 | 10:32 AM
rmkohn's Avatar
I had the same issue. Try pulling out the speed sensor(should be on top of the tranny) and spraying liberally with some sort of brake cleaner. If it works...thats your problem.
Old Nov 17, 2006 | 04:19 PM
IP RACING's Avatar
Default Re: (rmkohn)
thanx ... Ill try it tomorrow....have to go to work now... if thats not the problem what else could it be.. just in case
TigerLy
Aug 26, 2008 03:25 PM
jxhxb
Dec 29, 2007 08:58 PM
watacanga
Nov 29, 2007 08:47 AM
chrysler kid
Oct 9, 2004 10:50 PM
SpoolinEK
Dec 11, 2003 03:42 PM
