clutch, flywheel
Old Nov 15, 2006 | 08:08 PM
ridin98civic's Avatar
Default clutch, flywheel
looking for a clutch kit that includes lightened flywheel, any good brands? i would liek for it to have a stock feel to it. nothing to hardcore over stock
Old Nov 15, 2006 | 08:27 PM
petty$rep's Avatar
Default Re: clutch, flywheel (ridin98civic)
i have an 8.6 lb flywheel and it is def one of my favorite mods thus far
I have an Exeddy stage 3 clutch, it works extremely well, and the pedal pressure is not bad at all. I can barely feel a difference between stock clutch pedal effort and the stage 3. do you have a cable transmission or a hydralic transmission. if you have a cable tranny then i think the pedal effort will be pretty hard.
Old Nov 15, 2006 | 08:44 PM
Default Re: clutch, flywheel (petty$rep)
hydro- sry forgot to mention its a 98 ej8 with I/H/E stage2 crower cam. what did you pay for the flywheel and clutch kit if you dont mind me asking?
Old Nov 15, 2006 | 08:54 PM
wob's Avatar
wob
I was using a clutch masters 6puck and 8lb flywheel.. It was good while it lasted and only cost me no more than 450 total
Old Nov 15, 2006 | 09:15 PM
Default Re: clutch, flywheel (wob)
ok update: just found a great deal on a 7 pound fidanza flywheel, so now i just need a good and cheap (contradictory i know) clutch and pressure plate
is it possible for your clutch to slip but your pressure plate to still be good? its only a year old
Old Nov 15, 2006 | 09:33 PM
wob's Avatar
wob
Yes its possible for the clutch to wear before the p/p.. As long as p/p isn't heavily scored glazed or cracked it should be fine
Old Nov 15, 2006 | 09:49 PM
what would cause scoring glazing etc?
Old Nov 15, 2006 | 09:55 PM
wob's Avatar
wob
Excessive heat due to friction...
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Mar 2, 2015 05:02 PM
00pr3lude
Apr 2, 2008 05:21 PM
spoon23_JDizM AkA SpOoN20
Sep 17, 2004 04:34 PM
beandip
Nov 23, 2003 11:31 AM
Hondasaurs
Mar 3, 2002 09:24 AM
