vtec vS ivtec cam theory build
Old Nov 15, 2006 | 07:53 PM
Finger Lickin' good's Avatar
Default vtec vS ivtec cam theory build
so, ok integra guys. Your building a 2060cc b18c. Basically the theory after this is following after big brother. Why? cause big brother is the cheapest most reliabilable, call it selling out or whatever you want.
so, that leads me right in to what cam to use, what was initially my question. Staying oem, does the extra use of displacement affect which oem cam should be used. Im starting this theory by oem parts.
Ya but, do i know if there is a big difference between big brother cams(k20 type-SorR) and itr or ctr cams.
Let me break it down. You have a k20 type-S and a ITR sitting side by side. For arguments sake, say the cams are interchangable between the two with no modification. That said, how much would you measure the difference?
OR) and heres where i start to make too much sense, cause baicaslly, to me, the ECU has MORE THAN THAT, meaning the cams are such a simple part, the cam has nothing when it comes to WHEN the cam works. as in v-tec acting like an on/off switch or whathave you, and then its like the i-vtec acts like multipule switch. ya know?
soo, knowing not what vtec does, rather HOW it does it, compared to i-vtec, would the vtec motor NEED TO have a stage 1 after market cam like toda or whatever to keep up simply cause it does not have the on the fly adjustability used to monitor i-vtec.
Old Nov 15, 2006 | 10:14 PM
Default Re: vtec vS ivtec cam theory build (Finger Lickin' good)
ya i was just agreeing, i put a lot of work into that.
Old Nov 16, 2006 | 08:38 PM
for my delivery imagine this
hmotors b18c 96 obd2 complete change-over. 3149
sleeved service 2.0 850
11.5ish comp/ratio you fill in piston name "here" 500
hondata s200 300
LSD (future must have) 800
hasport mounts from hmotors as package deal 300
gsr TB matched or ITR TB matched intake manifold 50
GSR OEM ported throttle body 66mm 100
310 cc injectors 200
TOTAL-------------------------------------------------->>6249
for so much more i could have todas or jun. add 800 to 6250
and only 300ish sticking oem to it,
so
Old Nov 16, 2006 | 09:44 PM
anyone know what ivtec actually does vtec doesnt do already?
Old Nov 18, 2006 | 09:13 PM
bump up my post
Old Nov 19, 2006 | 11:13 AM
lightcrx's Avatar
ivtec isnt only vtec it also ajusts the intake cam, retards and advance's it like a ajustable cam gear thats never locked down and controlled by the ecu.... hope this makes sense
Old Feb 22, 2007 | 09:55 AM
joethejoeman's Avatar
Default Re: (lightcrx)
most ivtec only have vtec on the intake cam, the exhaust does nothing in the majority of ivtec motors. Some of them have both cams equiped w\ ivtec
luda8890
Feb 7, 2016 03:38 PM
250r king
Mar 13, 2010 10:32 AM
shaggyeg6si
Oct 6, 2008 02:42 PM
killaBc1
Jan 30, 2005 11:35 AM
Que_Lude
Mar 26, 2004 05:42 PM
