Guide to Buy a FI Vehicle
Old Nov 15, 2006 | 07:27 PM
Forrest Gump 9's Avatar
Default Guide to Buy a FI Vehicle
Just wondering what are some of the points to look for when buying a FI car? I'll start out with
-Compresion check
-Leak down test
-Dyno pulls to verify power and boost
What's else??
Old Nov 15, 2006 | 08:42 PM
a1320addict's Avatar
Default Re: Guide to Buy a FI Vehicle (Turbo9Nut)
Check the oil, as simple as it is, will show how well kept the car is.
Pull the oil pan and valve cover and verify internal components as stated by the seller.
Old Nov 16, 2006 | 03:33 AM
slow poke's Avatar
That would be sweet if you could put the car on a dyno before buying. lol
Old Nov 16, 2006 | 05:33 AM
bond007's Avatar
Default Re: Guide to Buy a FI Vehicle (slow poke)
Do a compression/leakdown test:that will determin the heath of internal parts.
Old Nov 16, 2006 | 05:37 AM
B18 CYA's Avatar
Default Re: Guide to Buy a FI Vehicle (bond007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bond007 &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression/leakdown test:that will determin the heath of internal parts.</TD></TR></TABLE>
uhhh, he already put that down
Old Nov 16, 2006 | 05:39 AM
RacerXI's Avatar
Pull the plugs. Check for oil, detonation, deposits, etc.
Old Nov 16, 2006 | 07:53 AM
b18sihatch's Avatar
i know this was said already, but its a number one, you want to know what kind of pistons,rods,rings,bearings ect it has and recipts to confirm or drop the oil pan!
your motor is only as good as your internal parts!
Old Nov 16, 2006 | 07:58 AM
Dunc's Avatar
BCICAN
Default Re: Guide to Buy a FI Vehicle (b18sihatch)
Knowing who tuned it. Basically was it slapped together by someone who thought they knew how to do it, or was it done by a reputable tuner.
jdm_ek_noob
14
Oct 27, 2013 11:59 PM
slateEKsi
Jan 26, 2010 11:46 AM
96lude_srv
Sep 9, 2007 08:03 PM
ek4b18c_r
Feb 6, 2005 05:18 PM
