gsr oem rod bearing colors question...
Old Nov 15, 2006 | 07:12 PM
NA JDM GSR's Avatar
Default gsr oem rod bearing colors question...
ok so you have to look at the letters and numbers on the crank and rods and match them with the appropriate color???
Old Nov 15, 2006 | 07:59 PM
Yambor's Avatar
there is a chart im sure you can find somewhere on HT..
the numbers on the rod with the letters on the crank near each rod journal..
then you plug them into the chart to see what color bearing you will need..
Old Nov 15, 2006 | 08:13 PM
NA JDM GSR's Avatar
Default Re: (Yambor)
wut about the letters on the block
Old Nov 15, 2006 | 08:19 PM
Yambor's Avatar
they are to be matched with the numbers near each main journal on the crank, a different chart is for the main bearings
Old Nov 16, 2006 | 08:30 AM
95 integra's Avatar
Yea, the block letters are for how large the hole is for the mains....then you have the codes for how large the mains are on the crank, how large the rod journals are and finally how large the holes are on the big end of the rod. 4 numbers total and you have to drop the oil pan, windage tray and oil pickup to read them off to order new bearings.
tico
Jan 4, 2011 08:43 PM
USDM-EK4*
16
Jul 11, 2009 06:05 PM
GSR-C5
Jul 1, 2007 05:28 PM
crxhf19
May 21, 2005 04:56 PM
SkRiBLaH
Jul 28, 2004 10:24 AM
