HELP me pass smog
Old Nov 15, 2006 | 05:47 PM
K20A_EH's Avatar
Default HELP me pass smog
How's it going everyone
So i just got this 1995 Honda civic CX and im planning on swaping the motor for a k20 so i figured that i should smog the car while its got the stock engine and easy (so i wonte have to worrie about it for 2 years)
and i have to so i can register it in my name anyway
well i went to the smog shop and they test it............FAILED
they tell me i need a new head......or a new cat.......and the CX CAT costs alot because it is part of the exhaust manifold........so i say can i just add another one under the car that way i'll have two CAT's.......he says that it should pass if i do that......ok so i got have another one added
I go back to test it again and.............FAILED again
now he said it could be the MAP sensor or the o2 sensor
i passed the high speed part of the test but not the low speed
HELP ME pass this thing so i can finally take it out and drop that k20 in
Modified by K20A_EH at 7:17 PM 11/15/2006
Modified by K20A_EH at 8:41 PM 11/15/2006
Old Nov 17, 2006 | 04:47 PM
TEST ONLY's Avatar
Default Re: HELP me pass smog (K20A_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20A_EH &raquo;</TD></TR><TR><TD CLASS="quote">HELP ME pass this thing so i can finally take it out and drop that k20 in...</TD></TR></TABLE>
k20-t?
Old Nov 17, 2006 | 09:47 PM
K20A_EH's Avatar
Default Re: HELP me pass smog (hazw8st)
k20a
Old Nov 18, 2006 | 12:57 AM
spork motorsports's Avatar
* B A N N E D *
take it to a TEST ONLY place it matters i think there thinning out your pockets,
Old Nov 18, 2006 | 10:16 AM
K20A_EH's Avatar
Default Re: HELP me pass smog (spork motorsports)
no the place is
"If you dont pass, you dont pay"
so i have'nt payed anything yet
Old Nov 18, 2006 | 10:32 AM
-JSpecEk*9-'s Avatar
the only thing i can think of is doin a 4 gas analyer(sp) so see what your emmsions are at.
Old Nov 18, 2006 | 10:54 AM
BUNNYz's Avatar
why don't u post the numbers out so we can see it what is wrong with the car? HC CO Co2 Nox
Old Nov 18, 2006 | 02:15 PM
K20A_EH's Avatar
Default Re: (BUNNYz)
yeah sorry about that
i'll post when i get home
Old Nov 18, 2006 | 02:58 PM
K20A_EH's Avatar
Default Re: (K20A_EH)
HC: 15mph: 7
25mph: 3
CO: 15mph: 0.00
25mph: 0.01
Co2: 15mph: 13.90
25mph: 13.96
o2: 15mph: 0.20
25mph: 0.18
NO: 15mph: 0972 max is 731
25mph: 0426 max is 798
this is with the stock CX cat and a under car cat and it was on 91 octane
Old Nov 18, 2006 | 06:47 PM
jdm_eg06's Avatar
Your nox is high....means your engine could be running very hot (leaning out) or your cat(s) is/are pooched. Try and richin her up a bit.
Old Nov 18, 2006 | 07:04 PM
blueshark's Avatar
Default Re: (jdm_eg06)
Failing NOx in smog checks for Hondacars is a very commen problem in pre OBD2 cars as they are nortorious lean burners and fuel is not refined to meet their air/fuel ratios. Anything you can do to lower combustion chamber temperatures will help. Larger injectors, Programable PCM, What ever works!
Old Nov 18, 2006 | 07:30 PM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_eg06 &raquo;</TD></TR><TR><TD CLASS="quote">Your nox is high... try richin her up a bit.</TD></TR></TABLE>
Good luck dude!
Old Nov 18, 2006 | 10:55 PM
K20A_EH's Avatar
Default Re: (hazw8st)
should i add a B&M fuel pressure regulator or is there someinthg easier
Old Nov 18, 2006 | 11:42 PM
mintscorpion's Avatar
how many miles on the engine. if there's a lot of carbon build up on your pistons it'll raise your compression ratio a little which will cause higher combustions which causes NOx. try running some sort of injection/combustion chamber cleaner.
Old Nov 19, 2006 | 12:00 AM
K20A_EH's Avatar
Default Re: (mintscorpion)
125,000miles
i'll try the cleaning products
Old Nov 19, 2006 | 12:47 AM
kuja396's Avatar
I feel SO sorry for you guys in Cali. I have a b18 in my civic and i wouldn't even think twice about not passing emissions. This will make you pass for sure, move
Seriously though, I would try the injector/fuel cleaner, check the spark plugs (might help), air filter, cat. Thats what I have done in the past.
Old Nov 19, 2006 | 02:49 PM
K20A_EH's Avatar
Default Re: (kuja396)
i have a short ram intake
and new plugs, plug wires, ditributer cap, rotor
Old Nov 20, 2006 | 06:31 AM
EE_Chris's Avatar
Is 91 octane what you should be running in a stock 95 Cx?
Have you checked the timing with a timing light?
Old Nov 20, 2006 | 09:54 AM
BUNNYz's Avatar
question after u put the second cat on. did u heat up the engine real hot and u should able to smell that new cat smell? Try heating up the engine for few mins above 1500rpm then do smog right away. don't shut down the engine.
double check on the timing and whether u have enough coolant in the system.
Old Nov 20, 2006 | 02:43 PM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20A_EH &raquo;</TD></TR><TR><TD CLASS="quote">k20a</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red">100%</FONT> no, you can't pass legally....
You're forced from this point on to pay extra <FONT COLOR="green">$$$$</FONT> for smog tests....</TD></TR></TABLE>
Old Dec 17, 2006 | 09:52 AM
hbcrazy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">take it to a TEST ONLY place it matters i think there thinning out your pockets </TD></TR></TABLE>
asonoasono
Honda CR-V & Element
Jan 10, 2011 07:06 AM
My_EFsedan
Nov 18, 2009 06:54 AM
ca177or4
Feb 20, 2007 08:15 AM
Anhjockz
Jun 1, 2004 02:27 PM
hndarcrb18c1
May 4, 2003 08:59 PM
