D16Z6 which distributor?
Old Nov 15, 2006 | 03:01 PM
allnaturalb16's Avatar
Default D16Z6 which distributor?
Im trying to finish a swap for my friend but the distributor is wrong.
We have a d16z6 block and corresponding head going into a 88 crx si.
The wire harness on the motor is original from the car and the ecu is stock also.
Everything plugs in but the distributor does not line up with the bolt holes on the head.
Which distributor do we need to work with the motor and still plug into our wiring harness?
thanks for any input
Old Nov 15, 2006 | 04:19 PM
91SiZ6's Avatar
You have to cut an ear off of the OBD0 distributor. You guys really should run it correctly though because even with an RPM switch the PM6 doesn't have fuel or timing maps for VTEC.
Old Nov 16, 2006 | 06:26 AM
Default Re: (91SiZ6)
what do you mean<U></U> "You guys really should run it correctly though because even with an RPM switch the PM6 doesn't have fuel or timing maps for VTEC."
Old Nov 16, 2006 | 01:44 PM
91SiZ6's Avatar
VTEC uses different timing a fuel maps than off-VTEC or non-VTEC. The PM6 ECU doesn't have maps for VTEC because the D16A6 isn't a VTEC engine. So, you should do an OBDI conversion so you can run the P28 ECU that comes stock with a D16Z6.
YangFlavor
Apr 29, 2019 01:53 PM
Kris's turbo
Apr 24, 2012 11:10 AM
dragva5g
Oct 28, 2011 07:03 AM
JJDd16z6
Sep 21, 2011 01:44 PM
-[95cxhatch]-
Dec 16, 2003 06:46 PM
