tranny not going into gear (just replaced slave and master cylinder) WAHTS WRONG!!!??
i have a 94 integra GSR and it wont shift right, i replaced the clutch master cylinder and the slave cylinder and it still wont go into gear, when i put the car into gear and start it up it wants to go but my foot is on the clutch completly. has anyone experienced this problem if so what is it, im lost.....
Air in the line most likely. Will it go in gear with the engine off? What about if you pump the pedal about 30Xs? If it will do either of those then its time to bleed and bleed some more.
Pump the pedal and it should shift, let it sit and it wont. Basically the air gets compressed, allows you to shift, you let it sit (even while you're driving) and it wont shift again. Thats what it sounds like to me anyway. I had the same problem after I replaced my clutch master cylinder.
Bleed it for sure before you take the tranny out. If you bleed it right and still same problem i can guarentee you clutch dics is bad. The Springs in the disc either melted to the disc or fell out.
well i took the tranny off and peices of the pressure plate fell out, and also the the clutch disc was bent a little and the springs were so loose that they could of just fell out.
that was the problem, i took it for a spin today and it shifts like a charm
thanks for the help
Modified by r1de4life at 8:52 PM 11/19/2006
thanks for the help
lo0nY
Feb 26, 2006 03:58 PM
ernestoG
Jun 19, 2005 08:29 PM
