help! video inside, no spark no start
Old Nov 15, 2006 | 01:53 PM
ek9jdm's Avatar
Default help! video inside, no spark no start
http://www.dropshots.com/day.p...61107
car won't start no spark everything inside the distributor has been tested all ok, why is this reading code 22, cAr ran fine when i swapped everything now it won't turn over haven't done anything different, swap came from HMO anybody know what i should do
Old Nov 15, 2006 | 02:30 PM
integra95gsr's Avatar
make sure your connections to the ecu are in all the way. The same thing happened on my friends and that was the problem.
Old Nov 15, 2006 | 02:49 PM
bg-33p's Avatar
Default Re: (integra95gsr)
LOL sorry i cant help but Night at the Roxbury is a great movie
Old Nov 15, 2006 | 03:54 PM
projectTeG's Avatar
check grounds.
Old Nov 15, 2006 | 06:26 PM
InfamousDC2FI's Avatar
Default Re: (projectTeG)
check your ignition fuses under the dash and in the engine compartment...
Old Nov 15, 2006 | 08:00 PM
Yambor's Avatar
what do you mean "tests" fine? just because you did a resistance test doesnt mean that the component is fine.. are you getting fuel but no spark?
you are very vague on your decription
Old Nov 15, 2006 | 08:01 PM
Yambor's Avatar
code 22 is pressure switch, check the t-stat grounds.
Old Nov 15, 2006 | 09:51 PM
ch4nq's Avatar
maybe you just have to replace your ICM in the distrubtor. thats what happen to mines and it worked. even tho it has current goin through it, its not functioning right.
Old Nov 16, 2006 | 08:25 AM
95 integra's Avatar
What all did you swap?
Old Nov 16, 2006 | 11:27 AM
ek9jdm's Avatar
Default Re: (95 integra)
swap is a 94 jdm gsr into a 91 integra with a jackson blower, with a obd0 to obd1 harness with my old ls harness, yes i'm getting fuel, i swapped out igniters with a good one, evrything else checked out ok, plugs came with the blower so they are new, when i did have it started it took forever to start, i'm running a p72 ecu all came with the swap from hmo, i'm gonna take some more video, in detail what i have done and i will post it up, thanks guys.
Old Nov 16, 2006 | 11:31 AM
95 integra's Avatar
Default Re: (ek9jdm)
Probably the wiring. Probably something on the engine harness that isnt lining up right.
Old Nov 16, 2006 | 11:32 AM
92DAIntegraXSI's Avatar
did u swap the dizzy to a obd1? when you go from obd0 to obd1 u have to change the dizzy to a obd1 also
headrec*
Apr 4, 2013 08:28 PM
awd_ftw
Jun 26, 2008 10:57 AM
sohc90rex
16
Dec 21, 2005 09:20 PM
stunt_driver
Jun 8, 2005 04:55 AM
MetalKill
10
Jan 30, 2003 07:42 AM
