heres my problem. bogging
Old Nov 15, 2006 | 09:42 AM
2poor2tune's Avatar
Default heres my problem. bogging
ok so i get in my car and drive it for a while and its great runs good and all. then as it starts to get warmer it starts to bog in the lower rpm's when im hitting the gas so to get anywhere i have to rev it up to about 3 and a half to get my car to not bog as i drive away. and its wierd when it does this becuase it will bogg and then if i hold down the gas long anough it will run good when i hit about 3 rpm's. there is one code but it has always been there. cly. 1 sensor. and i took the thurmostat out recently. let me know if you can help me. thanks
Old Nov 15, 2006 | 11:38 AM
2poor2tune's Avatar
bump. help me out please
Old Nov 15, 2006 | 01:16 PM
janz3n's Avatar
Default Re: heres my problem. bogging (2poor2tune)
that code is your problem.. look in the faq thread at the top and look for ecu codes and it will give you troubleshooting. why did you take the thermostat out?
Old Nov 15, 2006 | 01:18 PM
2poor2tune's Avatar
my car was constantly overheating and i was told to take it out so i did and no overheating anymore somehow. but that code has been around and it dident do this before so it wierd. ill try to fix the code right now.
Old Nov 15, 2006 | 01:20 PM
janz3n's Avatar
Default Re: (2poor2tune)
i think you have to replace the whole distributor to fix the code so good luck.. not running a thermostat is bad for the car. why didnt you just replace it with a new one.. isnt that expensive.
Old Nov 15, 2006 | 02:51 PM
2poor2tune's Avatar
Default Re: (janz3n)
i will thanks for the ino. replace both that is.
Old Nov 15, 2006 | 05:01 PM
90_civic_Si's Avatar
I`ve been trying to figure out this problem for the last 2 months. I had a d15b2, alot of kms it started doing the same thing.
Then i did the mpfi swap and there was a noticable difference in power but still same this when it warmed up. It worked awesome when cold, and when warm above 3 grand. Other than that it was the same bogging problem.
I started getting code 9(cyl position sensor)when i went above 4 grand. I didn`t notice anything difference when the CEL was on. I`d turn the car off and not go above 4 grand. I replaced the dizzy and that problem went away. Still same **** bogging at low rpm.
Next i replace the entire engine with a DOHC Zc, a little more of a difference in power, even better when cold. I still have the same problem. This is what i used from my old engine:
my modified DX harness for mpfi, injectors and resistor box. Everything else is different, why the hell is it still doing the same thing.
Old Nov 15, 2006 | 05:05 PM
janz3n's Avatar
Default Re: (90_civic_Si)
even though this started happening before the mpfi swap.. check and make sure your ecu pins are contacting fully.. mine werent had had the same problem.. also check your timing.
Old Nov 15, 2006 | 05:26 PM
I`ve checked timing probably 5 thousand times cause it`s the same kinda symptom, like it`s off a tooth. I wish it was cause then it wouldn`t be a god damn mystery.
I never check the ecu pins though, well i did but it could hurt to look a little harder, thanks.
I think i`m thread jacking kinda, but it`s sorta the same problem. I just want to be able to pull out across two lanes of traffic without being freaked out that my car with **** itself. It`s almost like i`m pulling away in second gear, thats exactly what it`m like.
Old Nov 15, 2006 | 05:31 PM
janz3n's Avatar
ya i hated it too.. took me a month to figure out that the pins werent in all the way. its cuz i kinda hacked the plug up a bit and they dont stay in very snug. but i never had that problem before i did the swap. and the rpm thing was definitly my distributor. 70 bucks at a junk yard for a crx mpfi dizzy
Old Nov 16, 2006 | 10:13 AM
2poor2tune's Avatar
hey dont worry about the thread jack. im learning here and i can probly get somthing to work right from this info. thanks. i need a obd0 b16 dizzy though and ill check my ecu pins because mine to was a dx and was swapped for mpfi at some shop out of town before i bought the car.
Old Nov 16, 2006 | 12:51 PM
janz3n's Avatar
oh you got a b16? it could be your o2 sensors then aswell.. dont know much about that stuff though.think its something about them being mixed up . i dont know
Old Nov 16, 2006 | 01:27 PM
2poor2tune's Avatar
haha or it could be the fact that i dont have any o2 hooked up right now. ill do that. and i need another one also. ill see what i can do. i am putting the turbo kit on in a few days so ill probly just wait till i get the down pipe and put them in there
Old Nov 16, 2006 | 02:22 PM
janz3n's Avatar
im not 100% sure of it but im guessing its cuz your o2 isnt hooked up lol. could be wrong though
Old Nov 16, 2006 | 06:21 PM
2poor2tune's Avatar
im lazy so i havent hokked it up yet but it did it bafore even when the o2 was hooked up but we will see. ill let you know
Hybrid_DA
Sep 2, 2011 02:55 AM
EJ ITO
Feb 28, 2007 05:56 AM
sickvtec
May 25, 2006 06:58 PM
SunkistRex
Apr 12, 2004 10:27 AM
