gsr sway bar on EK?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">This has been coverered before. You will need other parts as well.</TD></TR></TABLE>
If he has a complete sway bar, he'll need nothing more than si endlinks and si subframe brackets. That's all I needed ....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">why not just buy an aftermarket sway bar and save all the frustration of tracking down those parts?</TD></TR></TABLE>
Because....
GSR Sway Bar: $15 on ebay
ES OEM Replacement Bushings: $9 @ autozone
Si Brackets: $25 from Honda
CR-V endlinks: $10 from a junkyard
Misc Bolts: $1.xx at a hardware store
$60 for a fully functioning 14mm swaybar.
Because....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudgetBalla »</TD></TR><TR><TD CLASS="quote">how many ppl are actually running rear gsr sways on ek chassis that didn't originally come with bars? any reviews???</TD></TR></TABLE>
I am. It's better than stock, that's for sure.
gsr is 14mm si is 13mm, basically the same. I have a GSR on my ek, use the gsr d brackets and bolt it up. Use Si endlinks, and then i pressed out the bushing on the sway bar and welded in a metal grommet that resembles a stack of washers. it works great.
I had an si 13mm bar...it was better than stock, but not fantastic
About a yr later I sold the si bar, bought an asr subframe brace and 22mm itr bar....now Im extremely happy with the car's performance
i just went to a hardware store with the bar and foud some steel spacers and welded them in, you could use a stack of washers too, but make sure they fit the endlinks tight. I had to do it this way because the sway bar bushings were messed up.
Teh Boss
Dec 30, 2012 07:48 PM
Deano_D aka "Brick Top"
Jul 25, 2007 11:25 AM
RACEPAK
Jun 9, 2007 09:58 AM
