Two 02 sensors? what to do with them
Old Nov 15, 2006 | 08:05 AM
allnaturalb16's Avatar
Default Two 02 sensors? what to do with them
I have an obd0 b16a swap inot a crx and there are 2 o2 sensors available but i dont have any bungs to install them i was going to hve the local exhaust shop put them in but why do i need two?
Also i will not have a cat so does this affect them at all?
should i even install them this is a close to 200hp motor and i need performance?
Old Nov 15, 2006 | 08:13 AM
EE_Chris's Avatar
Default Re: Two 02 sensors? what to do with them (allnaturalb16)
An OBD0 B16 used two O2 sensors - one for cyl's 1 & 4 and the other for 2 & 3 (or maybe it was 1/3 and 2/4, but they were paired). Do NOT try and use one O2 sensor to feed both O2 inputs on that particular ECU though.
Old Nov 15, 2006 | 08:30 AM
Furyof4's Avatar
Default Re: Two 02 sensors? what to do with them (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">An OBD0 B16 used two O2 sensors - one for cyl's 1 & 4 and the other for 2 & 3 (or maybe it was 1/3 and 2/4, but they were paired). Do NOT try and use one O2 sensor to feed both O2 inputs on that particular ECU though.</TD></TR></TABLE>
The only way to run 1 o2 properly is to disable it in the ecu.
Old Nov 15, 2006 | 09:45 AM
Default Re: Two 02 sensors? what to do with them (Furyof4)
thanks guys i am relieved now
CTR-GSR
May 3, 2006 09:24 AM
plastik462003
Jan 3, 2005 02:46 PM
90hbvtec
Dec 5, 2003 07:42 AM
shadowstylz
Sep 3, 2003 07:07 PM
