a6 or y8 with vitaras
I have a y8 and a stock a6. I am going to keep my car obd0 and run turbo edit. Shooting for a realistic 300 hp. I've read all the timing and oil pump issues with the y8. I've also read how the a6 is the best d-series bottomend and vtec is worthless on SOHC. I'm on a tight budget so i was planning on using the o-so-famous eagle rods/vitara combo. I want to use the a6 with vitaras but it gets like 7.5 cr which is way too low. Even if there was a thicker headgasket, it still wouldn't get it high enough. Waht about the y8 bottom end with the a6 head. Kinda wanting to get away from vtec. What your opinions?
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13g-crx »</TD></TR><TR><TD CLASS="quote"> Waht about the y8 bottom end with the a6 head. </TD></TR></TABLE>
i may be mistaken, its been awhile since ive looked at CR calcs for these motors....but the y8/a6 combo will yeild the same CR as the a6 with vitaras...
the d16 CR is made up of head and piston differences, so swapping a bottom end will do nothing for CR...both blocks have the same deck height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13g-crx »</TD></TR><TR><TD CLASS="quote">I want to use the a6 with vitaras but it gets like 7.5 cr which is way too low. Even if there was a thicker headgasket, it still wouldn't get it high enough. </TD></TR></TABLE>
a thicker headgasket yields a LOWER cr
superhatchbackbros
Sep 30, 2010 05:59 AM
rasinhell
16
Jan 14, 2005 08:05 AM
shorty91
Jun 13, 2003 10:39 PM
