Clutch Help!
Old Nov 15, 2006 | 03:43 AM
accord23's Avatar
Default Clutch Help!
I have a 95 Accord manual transmission, and just yesterday the clutch is very hard to pedal. What happen now is that this morning I tried to start my car. The clutch seem to be very loose...and now I can't shift to any gear..I can still startup the car while pressing the clutch down very hard but just can't shift to any gear..Any clue to this..Please help!!!
Old Nov 15, 2006 | 04:43 AM
JimBlake's Avatar
Default Re: Clutch Help! (accord23)
'95 had hydraulic clutch, right? I'd say air in the hydraulic system. Bleed your clutch. If that doesn't fix it, replace master and/or slave.
Any fluid leaking? Check for leaking around the slave cylinder, especially inside the rubber boots. Check for fluid leaking from the master, it can leak alongside the shaft to the inside of the firewall, then soak into the padding underneath the carpet.
tercelrcr
Feb 2, 2013 06:25 AM
John 07
Oct 3, 2012 08:29 AM
Nuttynutnut
May 29, 2009 06:04 PM
integragsssr
Feb 6, 2009 08:54 PM
snyderman5
Dec 26, 2005 11:30 AM
