B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal?
Old May 8, 2002 | 03:43 AM
ITR1071's Avatar
Default B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal?
My car has issues, and I don't know what to do about them. When my car is rolling in neutral it idles about 500rpm higher than when it is stoped, so that is about 2000rpm. When I am on the highway in 5th gear I am at about 4500 rpm doing 75 mph. Is this normal? I get terrible gas mileage and I was wondering if my high idling/reving engine wsa the blame.
Old May 8, 2002 | 07:52 AM
BoM's Avatar
BoM
Default Re: B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal? (undercoverSI)
do a maintence step like 15k service
you have an SI, its tranny is extremely close geared
the tach is off also...but its suppose to be in the ballpark.
Old May 8, 2002 | 01:04 PM
blackANESE's Avatar
Default Re: B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal? (BoM)
4500 @ 75 seems about right. Remember B16's
were meant to rev.
Old May 8, 2002 | 03:47 PM
Katman's Avatar
ok the rolling-neutral idle thing can vary. So you're saying your car idles at 1500rpm when your car is parked-neutral? if so, that's too high. Try tightening the throttle adjustment screw on the throttlebody. It should be idling under 1000rpm, around 700-750rpm to be exact...
The 75mph@4500rpm is normal, thanks to the tiiite gear ratio a B16A tranny has.
Old May 8, 2002 | 05:08 PM
MaxBoost's Avatar
New User
Default Re: B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal? (Katman)
u should be @ 80 in 5th gear @ 4500rpm...not 75mph.
Old May 8, 2002 | 05:42 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal? (MaxBoost)
Mine is 4800rpm? or so at 80mph in 5th. S1 tranny.
MrViet
Mar 13, 2008 04:55 PM
nichols_si
Feb 2, 2004 09:12 AM
el arbi
Apr 21, 2003 09:31 PM
Hoagieryder
Dec 17, 2002 08:30 PM
