Quick Question about O2 sensor and if location has effect
Old Nov 14, 2006 | 10:54 PM
no2unenolife's Avatar
Default Quick Question about O2 sensor and if location has effect
Car: Integra 97 Gsr OBD2
the car came with a cat converter with
one o2 bung on the outlet of the cat. the primary o2 sensor is here because
the header did not have an o2 bung.
the secondary o2, is not installed but just put back into the hole where it comes out of.
I have no CEL, Motor is stock, i'm sure that the cat that came w/ it is not for GSR obd2 because after research the obd2 gsr has 2 bungs, inlet and outlet of cat
My question is that, does having the primary o2 sensor after the cat (outlet side) have any negative effects? Opposed to having the primary o2 before the cat
i have not found out the gas mileage yet but, just wondering if anyone can shed some light.
Old Nov 15, 2006 | 12:04 AM
blackdelslo's Avatar
Default Re: Quick Question about O2 sensor and if location has effect (no2unenolife)
That is a good question, I would think that by what the o2 sensor reads you would see very minimal gains by putting it on the inlet side.
Old Nov 15, 2006 | 01:39 AM
thanks for the input guys.
its weird that I dont get a CEL for my secondary o2, its just wrapped in foil and tape. i guess the car used to be running a test pipe.
so that was the "diy" simulator.
i'm hoping that it doesn't kill power or ruin anything by having it after the cat.
i wonder if the cat changes the a/f mixture at all.
at the moment i have no CEL so i guess i can be happy about that.
if anyone has any more opinions plz chime in
Old Nov 15, 2006 | 04:57 AM
JimBlake's Avatar
Default Re: (no2unenolife)
O2 sensor doesn't measure mixture, it measure oxygen. In the proper location, the primary O2 sensor wants to see some excess oxygen, which is needed for the cat to use. The ECU will adjust mixture until the primary O2 sensor sees the proper amount of oxygen.
Putting the primary sensor after the cat, it's measuring oxygen after the cat uses up what it wants. The ECU doesn't 'know' that it's after the cat, so it adjusts fuel until it's happy with the sensor reading. That should result in your engine running lean. (Maybe not a good thing...)
Old Nov 15, 2006 | 08:00 PM
thanks, anymore input
Old Nov 15, 2006 | 10:26 PM
Thought I'd add . ..
I remember when I had my car tuned, the tuner puts a sensor in the muffler.
so would this mean that having the o2 after the cat is still safe?
Old Nov 15, 2006 | 10:36 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">Thought I'd add . ..
so would this mean that having the o2 after the cat is still safe? </TD></TR></TABLE>Depends on how he used that sensor. Fair chance it's OK but can't guarantee from here.
ramboPandA
Sep 16, 2015 04:57 PM
beastman@
May 19, 2008 08:39 PM
apoptosis
Feb 9, 2008 10:51 PM
pizzamanprelude
Aug 2, 2006 03:26 PM
nos4a2si
Jul 19, 2005 11:58 PM
