is this normal.....e-brake console area gets warm
car runs normally fine, no overheat and temp gauge is normal.........but after a while the e-brake console gets warm. what the hell is goin on, is it the cat right below the car or what? cause its getting to the point where it fogs up my car...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_junior »</TD></TR><TR><TD CLASS="quote">car runs normally fine, no overheat and temp gauge is normal.........but after a while the e-brake console gets warm. what the hell is goin on, is it the cat right below the car or what? cause its getting to the point where it fogs up my car...lol</TD></TR></TABLE>
winters coming. leave it :-) haha
This is on EJ/EK, but I think the EG is the same: There's a rubber boot around the shifter underneath the console. That boot is the only thing between the cabin and the exhaust. Sometimes, especially if you've ever pulled/reinstalled the shifter, the boot can either get popped off or torn, which allows even more hot air in from the exhaust.
Take your console off and check the placement/condition of the boot. If you're getting heat in the e-brake area, it's probably leaking air from under the car.
Mine came off when I installed my short shifter, but I didn't find out why the center console was so hot until I took it apart like a year later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vindicator9000 »</TD></TR><TR><TD CLASS="quote">This is on EJ/EK, but I think the EG is the same: There's a rubber boot around the shifter underneath the console. That boot is the only thing between the cabin and the exhaust. Sometimes, especially if you've ever pulled/reinstalled the shifter, the boot can either get popped off or torn, which allows even more hot air in from the exhaust.
Mine came off when I installed my short shifter, but I didn't find out why the center console was so hot until I took it apart like a year later.</TD></TR></TABLE>
that happend to me but i fixed in a hour after the swap.
JackSparrow
Honda Civic (2006 - 2015)
May 22, 2010 11:55 AM
jaycetan
Aug 31, 2006 06:56 PM
b20guy
Jul 1, 2003 06:44 PM
