I know I know...Car will not start.
Old Nov 14, 2006 | 09:27 PM
bg-33p's Avatar
Default I know I know...Car will not start.
Yeah.. I searched and came up with about 150 results looked through about 10 and didnt find the same situation but came close. Which is this thread https://honda-tech.com/zerothread?id=1770172
Ok so this morning i drove to school, car off for about an hour and a half, go back outside and turn the key, NOTHING at all happens, heard a click and the "Maintanence Required Light" was blinking for a few times but does not stay on. Oh yeah i doubt it was the battery because i didnt turn on anything electrical during my drive and the lights could still turn on and my alarm still worked. I also had my oil changed within the last 1,500 miles and distributor cap, spark plugs, little things like that recently. So im totally stumped someone please help. thanks.
Old Nov 14, 2006 | 09:30 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: I know I know...Car will not start. (teggysue)
Nothing happened, as in it didn't even turn over?
Have you tried pop starting it, if the "click" was it not turning over?
Old Nov 14, 2006 | 09:35 PM
bg-33p's Avatar
Default Re: I know I know...Car will not start. (CleanLikeJdm)
Yeah it wasnt turning over, and sorry but what is pop starting? Ionno exactly wat the click was but i guess it was the engines failed attempt in turning over.
Old Nov 15, 2006 | 05:57 AM
Hype-R Stalker
Get it on a hill, or have a couple people push you,
Then put it into first gear while holding down the clutch,
Once you get enough speed, let the clutch out and it should jolt, and try to start.
A lot of people say you use different/higher gears, but I've always used 1st,
And it has always worked fine for me, but you could also use 2nd gear probably.
But anyways, the point of this, would be that if your battery, or starter went,
You could still start your car by manually turning it over,
So if the battery is dead, or the starter just won't crank, this is an alternative method.
Old Nov 15, 2006 | 06:14 AM
wreckedmyteg's Avatar
It sounds like your starter has a flat spot. You probably need a new starter (or have it rebuilt).
Old Nov 15, 2006 | 06:59 AM
Sam92Teg's Avatar
Default Re: I know I know...Car will not start. (wreckedmyteg)
Loose connections to the battery, starter, or grounds.
ef9_pr0jekt
Mar 7, 2020 07:44 AM
starbai
Sep 1, 2008 03:13 PM
int1992
Nov 10, 2007 10:16 PM
SlammedDC2
Nov 2, 2005 01:44 PM
indy
Jul 1, 2001 09:40 AM
