When I hit the brakes my seat belt lights go on Help! :)
Old Nov 14, 2006 | 08:43 PM
ESP-net
Guest
Posts: n/a
Default When I hit the brakes my seat belt lights go on Help! :)
Since I got back from the dyno...when I hit my brakes my seatbelt lights on the cluster go one and makes the racket noise...p28 ecu crome tuned...I un plugged the seatbelt sensor same thing...hmm i can't see the chip causing that to glitch somehow?
Old Dec 17, 2006 | 08:39 AM
kcjohnnyboy's Avatar
Default Re: When I hit the brakes my seat belt lights go on Help! :) (ESP-net)
i had the same problem, but i just did the 88-89 door on my 90-91 style crx. i also tried to plug in the 90-91 seat belts but still got the beeping and my seat belt light on the cluster lights up. and for some reason the door ajar lights up on the cluster everytime i brake also
bump for some help also
Old Dec 17, 2006 | 09:40 AM
crxrocks's Avatar
Check your fuses. I have seen this happen when the fuse is blown to the brake lights.
Old Dec 17, 2006 | 03:25 PM
Default Re: (crxrocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxrocks &raquo;</TD></TR><TR><TD CLASS="quote">Check your fuses. I have seen this happen when the fuse is blown to the brake lights. </TD></TR></TABLE>
i will prolly check tomorrow. where is the fuse located for brake lights, under the hood right? or dash?
Old Dec 19, 2006 | 07:48 PM
Default Re: (kcjohnnyboy)
and i just noticed my horn stopped working, and every time i try to use it, everything lights up
Old Dec 20, 2006 | 05:10 AM
sam0218's Avatar
fuse, the one under the hood
Old Dec 20, 2006 | 07:12 AM
ef9robert's Avatar
happens to me on my 90 si hb, make sure the seat belt on the door is secure and the door is fully closed. let me know if you find something out.
Old Dec 20, 2006 | 01:10 PM
im going to check fuse and wiring when the weather gets better and let you guys know
Old Dec 20, 2006 | 03:20 PM
SiRay13's Avatar
if it doesn't get better just unplug the sensor, under the seat.
Old Dec 21, 2006 | 01:14 AM
Default Re: (SiRay13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRay13 &raquo;</TD></TR><TR><TD CLASS="quote">if it doesn't get better just unplug the sensor, under the seat. </TD></TR></TABLE>
i've tried that and it still did it
Old Dec 21, 2006 | 11:46 AM
i went to take a look at the fuses. it turned out to be my fuse for the horn under the hood. replaced it and everything works like normal now. thanks guys
Old Dec 29, 2006 | 09:46 PM
JOE BD-0's Avatar
So your horn fuse solved the seatbelt / door beeping? ....My horn fuse is good and I still have beeping........any other ideas?.....
brownsEF
Jan 24, 2009 06:16 AM
freshly boosted DOHC ZC
11
Dec 28, 2008 07:49 AM
jobe_149
Feb 11, 2005 08:31 PM
2.2XDreams
Jan 21, 2005 02:54 PM
1sikcoupe
10
May 7, 2004 03:23 PM
