Axle Repair
Old Nov 14, 2006 | 08:00 PM
jpnucrx's Avatar
Default Axle Repair
How do you swap axle parts? I need to use GSR outers with prelude inners and need to know what do i do? I take the boot off and then what?..Please help. I need to get this car back on the road. Yes...Ive already searched...nothing in the search could help me
Old Nov 14, 2006 | 08:32 PM
Mario_D's Avatar
Default Re: Axle Repair (jpnucrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnucrx &raquo;</TD></TR><TR><TD CLASS="quote">How do you swap axle parts? I need to use GSR outers with prelude inners and need to know what do i do? I take the boot off and then what?..Please help. I need to get this car back on the road. Yes...Ive already searched...nothing in the search could help me</TD></TR></TABLE>
Once you take off the boot, you will see that the inner axle slips onto the outer axle via a joint. Remove them from each other taken care not to damage the splines.
Put the axles together in the same fashion taken care not to damage the splines on the shaft. When you put the boot band back on, make sure you have to appropraite tool to tighten the band. If not, you may risk damaging the boot.
m-
lazii_boi08
May 4, 2009 10:34 PM
K-Spec
Jun 14, 2005 02:09 PM
crazy eyez killa
Dec 8, 2003 11:50 AM
