F22B2 in 91 cb7
Old Nov 14, 2006 | 07:16 PM
DAfanatic's Avatar
Default F22B2 in 91 cb7
whats good honda heads, i have a simple question. I own a 1991 accord LX and it has a burnt exhaust valve on the #4 cylinder. My boy just put a F23 vtec in his 97 LX and wants to sell his engine and tranny for $150. Now being that his car is obd-2 and mine is OBD0 can i swap his engine and transmission into my cb7 and just use my distributor and ecu. All responses are greatly appreciated. Thanx
Old Nov 14, 2006 | 07:17 PM
DAfanatic's Avatar
Default Re: F22B2 in 91 cb7 (DAfanatic)
Oh if it helps they are both non-vtec and Automatic.
Old Nov 14, 2006 | 07:20 PM
Honda4lyf's Avatar
Whos gonna be doing the work?? If you gotta pay someone to do it, it's not worth it.
Old Nov 15, 2006 | 10:00 AM
DAfanatic's Avatar
Default Re: F22B2 in 91 cb7 (Honda4lyf)
No, Im doin all the work I just want to know will it run. Will the harness hook-up and do i have to use my distributor or the one on the F22B2. Cause I just need the car to drive no performance what so ever. And what ecu. thanx
Old Nov 16, 2006 | 04:41 AM
DAfanatic's Avatar
does anyone know??????????????????
Old Nov 16, 2006 | 06:18 AM
1CIVICLX's Avatar
you'd need an obd2 ecu. i beleive you have a p06 ecu and they cannot be burned with a vtec chip if i remember right?
Old Nov 16, 2006 | 06:49 PM
BlUAc's Avatar
Default Re: F22B2 in 91 cb7 (1CIVICLX)
well in your car ryt now you have a pt4 not po6 that actually can be chipped for vtec and to do the swap you will need to do some water hose rerouting but all else should be plug and play they all have the same sensors and plugs
Old Nov 17, 2006 | 06:20 AM
DAfanatic's Avatar
Default Re: F22B2 in 91 cb7 (BlUAc)
meaning some coolant rerouting, and thats it. F22b2 doest have vtec why do you keep talking about it. Thanx for the info Im going to start tomorrow. If I need help Ill repost.
Old Nov 17, 2006 | 07:23 PM
BlUAc's Avatar
oh sorry I thought you were swappin in a f22b2 from a f23 vtec read it wrong
Old Nov 17, 2006 | 09:25 PM
future62
Guest
Posts: n/a
You could just swap the heads...
Old Feb 7, 2011 | 07:56 AM
kadjs's Avatar
wat heads fit the 91 accord 2 door
Old Feb 7, 2011 | 08:53 PM
Brownjd's Avatar
any head from another F series engine will work. (any accord from 1990-2002 4 cyl of course) some have vtec which would make the install just a bit more involved. good luck!
Blackcb7
Jan 26, 2009 01:26 PM
redline870
Nov 18, 2008 08:46 AM
driveahonda
Apr 27, 2007 06:39 AM
6GACCORDH22
Feb 2, 2003 10:33 AM
H23 Power
Feb 3, 2002 06:52 AM
