no vtec and no codes.
Old Nov 14, 2006 | 06:59 PM
crxdxsir's Avatar
Default no vtec and no codes.
i just recently swapped a b16a into my crx swap went smooth and now i have no vtec, but the ecu is throwing no codes, if anyone has any suggestions or ideas i would greatly appreciate it.
Old Nov 14, 2006 | 07:12 PM
Zaakro's Avatar
Default Re: no vtec and no codes. (crxdxsir)
are you running a VSS?
Old Nov 14, 2006 | 07:15 PM
crxdxsir's Avatar
Default Re: no vtec and no codes. (Zaakro)
yes the stock one in the gauge cluster.
Old Nov 14, 2006 | 07:17 PM
Zaakro's Avatar
i thought the stock one is cable and not electronic
Old Nov 14, 2006 | 07:19 PM
STREETWERKZ's Avatar
oil level?
crxdxsir's Avatar
yes it is cable ran, but the vss is in the cluster, from what i understand. i did not have my cable hooked up and it threw the vss code, i hooked it up and i still have no vtec.
Old Nov 14, 2006 | 07:20 PM
crxdxsir's Avatar
Default Re: no vtec and no codes. (STREETWERKZ)
oil was between the dots on the stick, should be good.
Old Nov 14, 2006 | 07:21 PM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdxsir &raquo;</TD></TR><TR><TD CLASS="quote">yes it is cable ran, but the vss is in the cluster, from what i understand. i did not have my cable hooked up and it threw the vss code, i hooked it up and i still have no vtec. </TD></TR></TABLE>
what cluster are you running?
Old Nov 14, 2006 | 07:23 PM
crxdxsir's Avatar
the stock dx cluster with tach and speedo.
Old Nov 14, 2006 | 07:24 PM
DX cluster has a tach?
Old Nov 14, 2006 | 07:26 PM
Zaakro's Avatar
ok you need the Vss to run to your ECU and than to your cluster. now i believe you need a cluster with a electronic speedo and not a cable speedo. something like EF8/9, 99-00 civic si
Old Nov 14, 2006 | 08:39 PM
salman's Avatar
i didnt check mine for Vss,
zachvirus
Nov 27, 2007 12:37 AM
LudeJdm
Oct 8, 2006 03:02 PM
ITR.#1446
Oct 18, 2005 06:49 PM
boostin4door
Apr 8, 2004 09:41 AM
