cleaning carpet
Old Nov 14, 2006 | 05:52 PM
gator88's Avatar
Default cleaning carpet
i had mint carpet, kinda still do, until i couldnt avoid muddy feet in the car. i have zero stains in the floor, but these dirt spots that wont sweep out. I have a carpet scrubber with an attachment hose we have used on our beater subaru carpets before, worked great, but didnt care about consequences. well i want to know if its safe to use in the rex. it sucks about 95 percent of the water back out of the carpet, and i was worried about the little bit left over. i thought i could ude my heat gun and air compressor to fully dry it then, but what do you guys think is safe to do and effective?
Old Nov 15, 2006 | 02:46 AM
gator88's Avatar
Default Re: cleaning carpet (gator88)
bump.. i need help
Old Nov 15, 2006 | 06:10 AM
G0crxG0's Avatar
Use the steam cleaner or whatever, and then put fans on it.
Old Nov 15, 2006 | 06:28 AM
crxben's Avatar
Default Re: (G0crxG0)
I agree use a steam cleaner, if you dont have access to one just use your method. Just make sure to put fans on it
Old Nov 15, 2006 | 08:25 AM
G0crxG0's Avatar
****, if you can take the carpet out.
It only requires taken a few things out, but you do have to either cut your carpet behind the dash or take off the steel bar thingy thing thingy
Old Nov 15, 2006 | 08:37 AM
v8Buster's Avatar
look
shop vac it, spray it with a cleaner, wet it down a bit, shop vac it up, steam clean it and then blow air on it. works..
Old Nov 15, 2006 | 08:54 AM
G0crxG0's Avatar
Default Re: (v8Buster)
if you can man, I swear this will make your carpet like new:
If you got a air compressor, get a little air sprayer thing, and just sit and blast the **** out of your carpet, you'll get out all the little dirt and rock n **** more efficiently, then use the cleaner/steamer and unless it's HORRIBLY stained, it'll look like new (at least thats my personal method I like to use)
Old Nov 15, 2006 | 09:53 AM
gator88's Avatar
alright, yeah i have an aircompressor, ill try that for a while and see how it goes. thanks guys, it doesnt have any stains at all other than dirtspots...
B16Drag
Detailing
Sep 22, 2009 06:36 PM
Whatislove
Detailing
33
Jul 7, 2009 09:51 PM
Makdaddynuge
Honda Civic (2006 - 2015)
Jul 2, 2007 01:54 PM
schpiel
Jun 3, 2007 09:51 AM
pugphilly
13
Jun 16, 2006 05:42 PM
