crx with a crazy idle
Old Nov 14, 2006 | 04:17 PM
downsycrx's Avatar
Default crx with a crazy idle
i have an 88 crx si and i put on a header and a high flow cat then put a ported throttle body and intake manifold that is for an hf on my car. now it idles up to 4g and back to 800 in a lopeing fashion, it does this when i drive also unless it it wot can anyone help me fix this?
Old Nov 14, 2006 | 04:41 PM
Tyson's Avatar
Default Re: crx with a crazy idle (downsycrx)
ive had this before and my conclusion is that your idle is messed up and needs to be recalibrated.
there is instructions in the helms manual on how to do this. however, i suggest my method, as ive tried that and it wasnt successful.
what i do is basically find the idle adjust screw and lower it all the way. this is whe nthe engine is warm btw. then slowly raise it from there. that will do a better job of getting the ecu to correct the idle better.
ppl will tell you your TPS and/or IACV is bad or needs replacement. i tried replacing hte IACV and it didnt do anything. and i dont think TPS goes bad nearly as much as ppl suggest.
the other thing you should make sure is if your coolant is properly bled with no air pockets. it matters to the IACV as it has coolant passing through it to know when the engine is warmed up.
Old Nov 14, 2006 | 04:51 PM
downsycrx's Avatar
Default Re: crx with a crazy idle (Tyson)
i just got to looking the old intake was a hf-1 and the new one is a hf-2 was this a really bad mistake? and does that help anyone with finding the problem...still doing research across the web for differences in the two
Old Nov 14, 2006 | 04:53 PM
Tyson's Avatar
actually that hf-1 and hf-2 has NOTHING to do with whether it was for a HF or not. All the Si manifolds have "HF" something stamped for sure.
there is a difference in the 88 manifold, it doesnt have some sensor, i forgot which.
thats really not your issue tho. you just need to reset your idle. thats what fixed it for me at least.
thats all the advice i have for you.
dets93teg
Dec 13, 2011 03:46 PM
HBK
23
Nov 17, 2010 04:59 PM
beeastman123
Dec 1, 2008 10:05 PM
fireant
Oct 11, 2006 07:26 AM
DsMWookie
May 25, 2004 02:24 PM
